New headlight bulbs
Sylvania Silverstar Ultras, are they worth it? Im looking for a whiter beam instead of the normal yellow and i was told to get silverstar ultras but i have heard both good and bad reviews about them. Have any of you used them before?
Pro, Brighter
Con, shorter life, expensive.
IMO look for a set of projector lights for your truck.
Or what a lot of people do is put HID's in factory housings.. I did it in my old truck but be warned, doing this you will get flashed if you dont turn your beams down a little bit. Thats what Idid, aimed down a little and i was good to go in my old truck.
The Ultras would be ok if they are for your 2000. They have poor lifespan in any vehicle that uses the low beam lamp for DRLs, like the GMT 900s. I've got a set in my gmt 800, been going over 5 years now. Same for my Lincoln TC.
I guess the lifespan of the Silverstar Ultras varies from truck to truck. My '06 Sierra went through them every 8-12 months. I bought a set shortly after moving to Louisiana, and they are much better than the bulbs I replaced. Less than a year later, one went out, so I had to pull over and reinstall the good regular bulb I'd replaced with an Ultra. Having the mixed bulbs for a night or two really demonstrated how much brighter the Ultras are. Anyway, I bought another Ultra, then went with regular Silverstars, and finally, after replacing three or four bulbs in two years I got some Xtravisions. They've held up fine so far, are brighter than factory bulbs, and cost about 1/4 as much as the Ultras.
I have been running the SilverStars and have to agree the life is short always lasted a year. I have the ZXE now for about a year and a half so far so good.
pull the DRL fuses or disable them and you should have a far longer bulb life.
Fred why do you need to pull fuse for the DRL. just asking
With the GMT900 one way to keep the DRL's from coming on is to pull the fuse. Since the low beam bulb doubles as the DRL this gives you longer bulb life.
The DRL's essentially run your bulbs all the time whenever your truck is on. By disabling them you will cut the amount of time the bulb is being used. If a bulb has an example life span of 1000 hours, then anytime you use the lights via DRL or regular headlights it is counting against that bulb lifespan. It's a simple idea really, you are simply cutting the amount of time the bulb will be on, thus extending its life.
I bought a set of silverstars and returned them shortly after. They are a whiter light but they didnt seem that much brighter for almost three times the cost of stock ones. Also life expectancy on them isnt very good, would not recommend them, get a good set of HID instead.
    • $4.35 85 oct.
    • For 2 years doing repairs or maintenance has not easy with my physical issues. Something simple isn't simple any more.      Sept. 6 2024 left shoulder 2 rotator cuff tears, bicep torn from bone. Still having issues, pain and dexterity problems left hand. Go to have EMG test on the 27th, second test. I'm left handed.   Oct. 3rd 2025 right hand carpal tunnel surgery and ulnar nerve,  end of 3 fingers still lack good feeling. Makes it difficult to do things.   March 3rd 2026, Cervical fusion, 4 vertebrae. Still have pain in neck and upper back.    I put upgraded shocks on our side by side, not hard but it took me over 2 hours. Oil changes are frustrating because nothing works like it used to.
    • 3.47 Kroger’s in Montgomery Tx
    • I can relate. 3 years ago I did that on my Avalanche. I was sore for a week. The only maintenance I do myself now is drop and fill on the transmission on my Honda’s. It’s just too easy. My yard work with my walks in the morning will be enough now I passed 70. The contributing factor is the heat in Texas. You just have to pace yourself.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
