So If I bought the 4.5 Zone Lift without adding the AAL or changing the blocks, my truck would still have a slight rake?
if you used the 4" blocks the kit comes with you'd have about 1/4" rake
The kit i was considering comes with new upper control arms and shocks if i chose that option, truck only has 22k miles, so not sure i need or want to change the shocks already.. may get that kit anyway just to have the shocks on hand when its time to replace
http://www.tuffcountry.com/lift-kits/chevy/silverado-1500/
dont get that kit, it does nothing to correct the lower BJ or TRE angles
Edited by wildchevys
So my truck is 2wd LT
Didnt have a chance for the pic at lunch today. Will do after work and post then.
I plan on doing the install myself, as i did on my past truck.. the kit i was looking at from tuff country is the
4″ 14057
You should look into a spindle lift for a 2WD truck. Achieves lift and preserves good angles. I'll link a couple places for you.
Maxtrac Suspension
CST
Maxtrac Suspension
CST
Thanks for the suggestions.. the prices though are out of my price range.. If I can find a good kit for $500 or less that's what I'm looking to get.. the rough country kit is better deal than the tuff country kit I was looking at.. I was able to take a pic of the control arm and tested with magnet, so its not the aluminum kind.. but not sure the angle of the picture is good enough to tell if its the stamped or cast one.. ill post in a few..
Edited by cubangt
Remember, you get what you pay for
yea I know, but thousands is not in the budget and wont be for a long time.
Zone is like $1200
Maxtrac Suspension
CST
I have a 2014 SLT 1500 with the GMC 20x8.5 wheels. I did the 4.5 spindle kit from maxtrac suspension and fit 35x11.5x20 Nitto Ridge grapplers, no spacers and without trimming or rub. Truck sits level and rides well. 4.5 was just right for my 2WD daily driver. A shop here did it in 3.5 hours for 1200. Very impressed with it. Great suggestion
You have the same upper control arms as I do. What are you trying to accomplish with your lift? 33" tires? Larger? Or just a decent size lift...
Maxtrac Suspension
CST
So the install was $1200 beefjr? or that was total kit /install cost?
My last truck I was happy with the leveling kit.. was able to put on some larger tires and get a more aggressive look.. with this truck I wanted to step up to a lift instead of just leveling kit.. so figured the 3.5"/4" lift would be the step to take..
I'm not in need of new tires yet as the truck only has 22k miles on it.. but will def upgrade to larger more all terrain tires when its time..
I see. Beefjr detailed his setup for you. The 4.5" kit runs around $650. Comes with everything you need.
Here is a link to realtruck.dotcom for every Maxtrac lift for a 2015.
    Tbhats2130
    Tbhats2130
  • Who's Online   1 Member, 0 Anonymous, 2,227 Guests (See full list)
