Got a question, after reading thru majority of the posts in this section on lifts, still questioning my next move.. Im finally at a point where i can get a lift for my truck, considering the 4" over the 2" leveling. Although i have the money now for the lift, i dont so much for the tires... besides the look(temporary of course) can i still do the 4" lift and stick with the stock rims and tires until i can get the new tires? Will the stock rims work ok in the future? Meaning i dont need a new set of rims with offsets to benefit from the lift?
I dont want to get the lift if im going to have to replace more than just the tires..if i can stick with the stock rims and just go with a larger tire then im all in..
Before this truck i had 2011 F150, level kit and squeezed in some larger tires on the stock rims and looked great.. never had issues.. was hoping to do similar on this truck only with a 4" lift instead of just leveling kit.
thank you
These are the rims i have on the truck, if anyone has the 4" lift with these rims and larger tires could you post a pic of how the truck sits.. i didnt got thru all 222 pages of this section, so if there is any already out there if you can point me in the right direction to the post to review..
The stock wheels SHOULD work but ultimately it comes down to the brand lift you choose and your control arms (stamped steel, cast, aluminum). I have stamped steel which have a nub that sticks out in front of the ball joint so you can't run stock wheels with the Zone lift with stamped steel control arms (I found out the hard way) so just do your research
Ill try and take pics and post after lunch today. The lift i was considering was the tuff country 4" 2WD kit. Im def trying to do all my homework before i make the purchase. I dont want to get the kit installed and find out i cant drive the truck until i get new rims.. so def want to make sure..Ive already emailed tuff country for validation of the kit and anything i should be aware of.
Edited by cubangt
I'd go with BDS or Zone over tuff country ALL DAY
Edited by wildchevys
thank you
Here is my truck with a Zone 4.5" and stock wheels (1.5" rear spacers). Stamped steel arms and zero rub. The tires are 275/65 20's (34.5")
If you work/live in or near Downtown, I'd be more than happy to meet up and let you see the truck.
BTW, if anyone is looking to change their 4.5" lift to a 6.5" lift, I have the kit listed in the classifieds forum.
http://www.gm-trucks.com/forums/topic/199328-zone-45-to-65-upgrade-kit/?do=findComment&comment=1959500
Edited by n77nxc
are the tires close to rubbing the UCAs at full lock??
I have the Zone 4.5" and I was going to run the LTZ 20s on 305/55s but the tire was rubbing the UCA pretty bad
Looking at the price, both BSD and ZONE are alot more than i wanted to spend..
n77nxc, thanks for the pic, is it just the angle, or is the front still sit little lower than the back? Arent the kits suppose to level them out after install? or will there always be some rake regardless..
Im actually located out in Katy, from time to time ill head down that area, typically on the weekends..
No sir!
I don't get it lol
the Zone 4.5" kit keeps the truck with about 1/4" of rake.
I ordered the kit with 3" rear blocks instead of the 4" because I wanted a level look. Even though I'm 3/4" higher in the front it still looks perfectly level.
There is a bit of rake in the truck but that particular picture makes it look more exaggerated than it actually is. The 4.5" does not level the truck. Supposedly the 6.5" sits more level.
Katy is actually closer to where I live in Richmond. Either way, I'm more than happy to meet up.
I'd listen to what most are saying and get a lift that lowers the front lower control arms. Its essential to make sure everything works in sync. Believe me, I had a hard time justifying 1K for the kit also.
Edited by n77nxc
cuban - Is your truck 2WD or 4WD? If 2WD, the install is a breeze. No cutting, no welding, all bolt-on.
There is normally a slight bit of rake, like 1/4"-1/2" but it's easily leveled out by getting a smaller rear block or adjusting coil overs if you have them
So my truck is 2wd LT
Didnt have a chance for the pic at lunch today. Will do after work and post then.
I plan on doing the install myself, as i did on my past truck.. the kit i was looking at from tuff country is the
4″ 14057
I plan on doing the install myself, as i did on my past truck.. the kit i was looking at from tuff country is the 4″ 14057
im pretty sure that's a glorified leveling kit and not an actual lift kit
I don't get it lol
So If I bought the 4.5 Zone Lift without adding the AAL or changing the blocks, my truck would still have a slight rake?
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 561 Guests (See full list)
    • And to top it off finally.......................these small GM LS engines are designed to SPIN!!!!!  Why choke them down to just off idle for cruising.  Why/how the "bean counters" have influenced the "engineering department" at GM is beyond me.   They took a solid platform of an engine and turned into a joke in OEM form!!!
    • Atlas,   Then following your logic we can't believe any story that the MSM produces? I mean it's documented they heavily donate to Democrat candidates. Vote Democrat in high percentages. Many MSM talents are married to Democrat politicians, Gov. employees. That goes for on-air and off, personalities and reporters. So they would all be biased and nothing they produce is to be believed in your mind?   Again the article simply was about ways AI can be used for pricing products. Nothing discounted current situations as a factor.    Again keep looking through your left/right lenses. I don't live my life that way.   And as a heads up this thread will be cleaned up again as much of this is off topic and is receiving
    • Yes, and only a couple years before delivery. 🙄
    • So you're saying toss the baby out with the bathwater? @txab posted article was her take on how AI can be used to manipulate pricing as it already does and has been rebuked by the judiciasry in housing. How AI can be and is used to maximize refinery or even Amazon operations all of which are true but because she is who she is; that makes what she says about what is true, false? Is that something akin to Pre-justice aka prejudice?    Look, I'm first in line to approach all information with caution just because we live in a world where people like to lie about someone or something with such a straight face and in such volume that it makes digging to the truth wearisome. Meaning I understand the skepticisms but if I were to toss out everything a person is for a view they hold then my pool of people to draw wisdom from would be non-existent and I'd be forced to reinvent the wheel daily. Not practical.    "Be innocent as a dove but as cautious as a serpent."    Test each word. Every good lie is part truth or no one would believe it. Find the truth in it and reject what isn't.    On this one, AI is being used to do what has been done by hand for hundreds of years already but at such speed, the point of a computer, that it is more easily monetized. This one wasn't that hard a lift.    I wrote a few formulas in a Lotus 123 program decades ago, a series of linked Macros actually, that allowed a daily inventory to be turned into a running P&L and production plan. Something that took three departments a week to assemble now took the time it takes to input the 'daily changes' in inventory. Later that was ungraded to the more powerful Excel program an and integrated with bar code scanning, inventory to supply was done once per shift. It had a huge impact on production scheduling, Seamless interruption flexibility, inventory error reduction, raw materials cost effective utilization and scrap reduction. Huge improvement in the bottom line. I spent months on that and AI could have done it in minutes. So yes, it not only can be used, they would be foolish to not try. The legality, ethics and morality are not the domain of AI. Humans need to keep a reign on it.
