If you get a chance to get a photo from the side just to see how much the tires stick out, i'd appreciate it! I really want to get the Zone 4.5'' lift with 35's but I don't want to have a rub that I can't fix/trim. Also, you guys suggest the RT's over the MTs? Just noise level? Or ride comfort as well? Thanks!
Best side-ish shot I have on my phone. Zone 4.5" with 305/55s on 20x10s
I'll get a dead on side shot this afternoon
Thanks Wildchevy, your truck looks awesome man. Ill be going with 20x9 with 20mm offset so i dont think mine would be stucking out much. Just need someone to tell me to buy the 35s and risk an easy trim job.
thanks!
I've got the Zone 4.5 and its done very well. no problems out of it. I dont have any pics of the angles right now though. i'll try to get ya some
Looking to do the same. 14 Sierra SLT 2wd with stock 20 wheels. What tire size are you running and how do you like the kit? Thanks
Edited by Beefjr
Got a few shots for ya...
Very dirty but it's too chilly to wash right now
Remember i have 1.5" spacers in the rear and nothing up front...
All is just ur standard 4" BDS lift with the 35x12.5x20 toyo RTs
5b5dea4022422de5e2ca304e9f47e95f.jpg0483b4b74f2702f5d030dc94ed71aa2a.jpge14893b2fc29163c0345eda35495eaa5.jpg
Sent from my SM-G935V using Tapatalk
With the Fox coilovers my truck definitely rode better than stock.
Sent from my SM-G930V using Tapatalk
Well yeah I know yours does man lol. So does mine with fox coil overs. But the dudes with a 7" rough country, for example, are smoking something haha
Probably crack or bath salts, possibly a combination of both lol.
Did you have to do any trimming for the 35s to fit?
Sent from my Pixel XL using Tapatalk
Not one bit of trimming was done. If anything it just rubs the liner a tad in reverse at full lock. It looks wayyy close but everything fits just right.
Very nice. It's a similar setup that I want to get. I want the 4 inch BDS lift. How far out do the tires stick? I read because of the knuckle on the BDS lift that the front is out further than the rears. So I assume they stick out a bit and you need to get fender flares. But from the picks it looks like you don't need that. Maybe if I don't go for as wide as a tire, they will tuck in just nicely.
The tires stick out about an inch from the fenders. The fronts get pushed out because of the kit and the rears stay tucked inside. I have OCD so i had to space out the rears with a 1.5" spacer to even out the look or i would have gone crazy looking at the difference.
Sticking out is all personal preference but i very much like it when the tires stick out just a little.
Agreed. I think the tires sticking out a little looks great. If I go with the RCX 5" I'll need spacers for the rear as well.
I was running 295/60/20s and still rubbed at full lock with some trimming.The kit itself was a good kit and could complain. i did have coilovers custom built for the kit so that helped out on the ride. I just traded my truck last week lol.
Fabtech 4" lift, 295/60/20 trail grapplers on 20" BMF REPR's
Looks great!! How's the ride any issues with the lift after some time?
Thanks
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
