What uca’s? Some of those 4” kits I posted earlier that come with new uca’s still require new wheels cause they will still rub on factory wheels with bigger tires
Get a Zone kit with perhaps FTS UCAs and stocks might work
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
17 minutes ago, chrispassas21 said:
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
Are they uniball and do you have any pics? What size tires?
BDS w/stock 20s
4.5" Zone
Thats also a 6" lift .... NOT the 4.5" lift.
Do you know if 0 offset would clear on stamped steel uca’s?
I have stamped steel arms as well. No issues with my setup/no rubbing.
If you're in that much of a hurry to prove me wrong then at least take the time to post info with the same lift height in question. [emoji108]
Uniball with the stock 265/65R18 duratracs .....I believe that’s the tire size. Whatever the midnight edition comes with. What kind of pics do you need?
Just want to see what the truck looks like with that height on stock wheels and bigger tires.
3f8c15b353d76d9ee3a1ae193096414f.jpga757f7a226b3faaef93ace37d6e68ad0.jpg8dba16632a790b01c8d51d6432334d6a.jpg
I plan on going with bigger tires when I need to get new ones. Probably 33’s maybe 35’s not sure yet
It is LITERALLY the SAME kit. Different struts and blocks are the ONLY difference .
Do a little more research and i won’t have to prove you wrong, you’ll do it all on your own........
4.5" Zone
d7b2b691b502b77397be5b8e056dc436.jpgZone 4.5” on stocks (same as bds)
4.5" Zone
Looks really good. Thanks for the pics. You’ve got quite a bit of cash in that thing!
Thank you! My very first vehicle purchased brand new at 19 years old! I’d say I have around $5k in parts on it.
It is LITERALLY the SAME kit. Different struts and blocks is the ONLY difference .
4.5" Zone
If it's literally the same kit t hen why is it a different brand name?
If it's literally the same kit t hen why is it a different brand name? Sent from my SM-N950U using Tapatalk
Research Zone/BDS, it’s the same company.
And i said the BDS 4/6 are literally the same kit, as are the Zone 4.5/6.5. I did not say BDS and Zone are “literally” the same kit, although they are EXTREMELY similar
4.5" Zone
Zone and BDS are sister companies both owned by Fox. Their kits are ROUGHLY the the same.  If you want to get technical, BDS comes with top of the line struts and shocks, whereas with Zone those are add-on options.  BDS also has a no questions asked warranty on all of their parts, Zone has a limited lifetime warranty.
If you're going by kit, the BDS 4" and 6" kit are the same.  The only difference between the two are the height of the steering knuckles, and the spacers (to keep stock geometry). So really, same parent company, roughly the same warranty, and the same parts (with the exception of BDS's struts and shocks).
And obviously the price.  BDS is about $800 more expensive.
Edited by FootballCoach53
    DM22
    DM22
  • Who's Online   4 Members, 0 Anonymous, 1,694 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
