Zone and BDS are sister companies both owned by Fox. Their kits are ROUGHLY the the same.  If you want to get technical, BDS comes with top of the line struts and shocks, whereas with Zone those are add-on options.  BDS also has a no questions asked warranty on all of their parts, Zone has a limited lifetime warranty.
If you're going by kit, the BDS 4" and 6" kit are the same.  The only difference between the two are the height of the steering knuckles, and the spacers (to keep stock geometry). So really, same parent company, roughly the same warranty, and the same parts (with the exception of BDS's struts and shocks).
And obviously the price.  BDS is about $800 more expensive.
The 4 and 6” kits use the same knuckles. The only difference is struts and blocks.
As for Zone/BDS other than the struts/ strut spacer difference the basic makeup of the kits is identical.
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
Just now, jimmyboy8301 said:
The 4 and 6” kits use the same knuckles. The only difference is struts and blocks. Other than the struts/ strut spacer difference the basic makeup of the kits (Zone/BDS) is identical.
4.5" Zone
No shit?  Some jack-knob on another forum told me the knuckle height was different!
Nope, it’s the same knuckle. The 6” kit basically just adds 2” to the 4” kit. With bds, it’s a longer strut, with Zone it’s a larger spacer
I’ve had 3 BDS kits and 2 Zone.
4.5" Zone
I’ve had 3 BDS kits and 2 Zone. On my previous tuck i converted from the 4.5 to the 6.5 kit, and all it was was struts/blocks.
4.5" Zone
4.5" Zone
Crazy! Well... Always good to know.  I'm going with Zone until my stock struts wear out.  Then I'm putting in 4-6" lift struts.
It’s gonna look great! Both Zone and bds are excellent kits
4.5" Zone
4.5" Zone
Slightly off topic.... Did you trim your lower valence?
I removed the lower portion (it’s 2 pieces) and i angled the edges
4.5" Zone
I just swapped out the white hydraulic shocks that come with the zone 6.5 kit with Fox 2.0 shocks and the difference is very noticeable, in a good way. For anyone on the fence about which shocks to get with their zone kit, get the Fox 2.0 shocks !
Think I’ll have to do this, as well. I found a shop that will install for $980 out the door.
I paid around the same, California prices are so much higher than other states, I hear of people paying way less at shops, not so lucky here [emoji16]
5 minutes ago, arkenzo said:
I paid around the same, California prices are so much higher than other states, I hear of people paying way less at shops, not so lucky here emoji16.png
Dude... I was quote $4800 for everything.  Found a shop that'll do it for a grand less.
$800-$1000 is the average here i think
4.5" Zone
Zone 4.5 with a 3/4" spacer under the strut. Rear has zone 4" block with aal.
275/65r20
On a side note would not discourage anyone from installing the lift themselves took about 7hrs for 3 of us not rushing with jacks and stands.
Edited by tx2014
I did mine in the driveway, by myself in 20-25deg weather and it took around 12hrs total split between Saturday-Sunday. Directions are extremely well written, I went down the list step by step checking them off as I went.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
