22 hours ago, Joe Gurney said:
Just ordered the Rc 2.5in level lift kit. Will I be able to fit 305/55/20 falken wild peaks on my stock 20's with little or no rubbing? Looking for people's experiences/advice with this set up or a similar one. I appreciate any feedback. Thanks!
I installed the zone 2” lift on my ‘14 and now have 305/65/18 on stock rims. I have rub at full lock in reverse on the liner and partial rub on the mud flap at close to full lock
On 1/29/2018 at 1:22 PM, jimmyboy8301 said:
Take a pic of the front of the lower control arms and with a 5” block and no add a leaf the bds kit should sit level
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
I apologize that it took me so long, but these are definitely stamped steel right?  Are there any good magneride kits out there that don't widened the front stance?  That's my only issue with BDS.  I'm ready to get this thing up in the air!  Also, these are the wheels I'm planning on putting on, 22x10 with -18 offset.  I figured a black/chrome wheel  would look perfect on my black with lots of chrome Denali.  Thanks!
I don’t think there are any kits for magnaride that don’t widen stance. And yes those are stamped steel
4.5" Zone
Quick question for you guys, at a 6.5” lift and 35s on a Sierra 1500, what’s my total height going to be? I’m scouting car washes in my area. Lol
8.5” more or less
4.5" Zone
8.5” more or less
4.5" Zone
So we’re looking at like..... 7’ to 7’2”?
I’m not sure, but i know your total lift will be about 8.5”
4.5" Zone
4.5" Zone
Just did the math. I’ll be just under 7’0”, as long as my ride height is the 74” it has listed. Haha looks like I’ll be taking a tape measure to it when all is said and done.
So took one of my rims off this weekend to measure and check backspacing and such.. found the flatest and straightest thing i had to lay across the rim lip, measured down to the flat surface that touches the disc brake surface and it measured right at 6" or little less.. , but def between 5.75" and 6"
The Zone 6.5" 4WD kit i order calls for the following if using 20"
Wheel Size: 20x9
Back Spacing: 5.75″
Max Tire Size: 35 x 12.50
If its truely 6" backspace, would my rims work for the lift and all i need is new tires?
My rims are 20x9, have 27mm offset and between 5.75" and 6" of backspacing.
Edited by cubangt
You SHOULD be ok
4.5" Zone
thanks, i just heard back from Zone as well, they did recommend adding 1/4" spacers, but i will try both ways.
Don’t forget you should also do 1.5” spacers in the rear to even track width
4.5" Zone
well crap, as soon as i heard back from them i placed an order for 4 - .25" spacers so i can go ahead and get ready for the install
Lol, I’d cancel them for (2) 1.5”
4.5" Zone
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
