What issues have u heard about bracket lifts?  I'm still on the fence for what lifts I'm gonna do eventually.  I know the truck "needs" one (crew cab std box so it's a bit like a limousine)
I’ll be honest, I can’t remember off hand. Both lifts have issues depending on who you talk to.
anyone running King with UCA? how much lift does King offer for front and rear.
not interested in using blocks or spacers.
Edited by eyekyu
So I've had the lift now for about a week or less.. And want taller lift :)
but i'm posting here to ask about noticeable drive train shifting/engaging.
This weekend we went to the beach, and few areas required putting the truck into 4wd low to get thru some of the really loose sand..
No issues for us, but every once in a while it almost felt like it was slipping a little and then engaging again. Ive never owned a 4wd, so cant say this is normal or not normal, but wanted to ask..
I do have to check the fluid level in the TC, since during the install some fluid did come out, but ive noticed the same sort of slipping/engaging in 2wd as well...
What is or is not normal for 4wd lifted truck.. i probably wont drive in 4wd again for a while, so ill be checking and filling the TC fluid this week, but the normal day to day driving is what im more concerned about..
4 hours ago, rkmurphy526 said:
Anyone have any pics of a ‘14-‘15 Z71 with a Zone 4.5” that kept their stock 18s?
Check out customwheeloffset.com
Check in the gallery. You can search exactly what you want to do and get an idea what it would look like or just browse for ideas. Others suggested it and I was a bit skeptical but they have a TON of pics. I even found something for my weird taste.
Thanks.  Looks like it'll work with wheel spacers.  If I go with Bora spacers, is there any maintenance that needs to be performed outside of bolting them on with some thread locker?  If I have to remember to tighten them every oil change, I'd almost rather just get new rims and sell the old ones...
Can't help you on that one. I am getting new rims but trying to figure out exactly what offset I want and whether I want spacers or not. Don't have experience with them as of yet...
I have the bora spacers on rear and have no issues. Torque check at each tire rotation...
Hey guys - I have searched all through this forum and cant seem to find any info...
I got a 6 inch lift on my truck and there is about 1.5" difference in rake. I like the leveled look more - you guys recommend getting a 1.5" spacer up front? Or just leave it alone?? Thanks
What lift do you have?
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
4.5" Zone
I honestly have no idea. I just bought the truck and it was on there already..
Smaller block in the rear would be the way to fix the rake. I personally like and need the rake because I use the truck as designed.
Yeah I’m not hauling a lot around so it is more of a cosmetic thing for me.
You should probably do a little research
4.5" Zone
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
