You should probably do a little research
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
I’ve looked around - how do you find what brand of lift I have when there are no stickers or any of that crap all over it.
Get a good pic of the front crossmember
4.5" Zone
4.5" Zone
Let me know if this works - I’m new at this
Looks like a Zone off-road lift. They make a 4.5 and 6.5 kit
4.5" Zone
4.5" Zone
Pretty sure it’s 6.5. It’s just got a pretty big rake on it. Didn’t know if most guys did a 1.5 leveling kit or not. Don’t wanna mess this thing up if it’s not necessary.
The 6.5” kit is basically maxed out at 6.5” , meaning you can’t lift the front any higher (safely). The 6.5” kit is really a 4.5-6.5” kit. It can be run from 4.5-6.5” if lift. They come with a 5” block which SHOULD make it sit a tad leaned. It check to see the size block in the rear first.
4.5" Zone
4.5" Zone
Yeah just measured it’s a 5” block. So I guess it is what it is. Not gonna go and make anything more complicated or risk messing something up. Thanks for the info man you been awesome!! ??
Glad to help! If you have 1.5” of rake with the 5” blocks you definitely have the 4.5” kit, unless blocks are stacked
4.5" Zone
4.5" Zone
Interesting.. so is there a way to raise the front end 1.5”??
Not with the 6.5” the kit is already maxed out
4.5" Zone
4.5" Zone
Man I’m confused....the block I have is 5”, you mentioned I have a 4.5” kit. How is that? The 4.5” kit comes with a 4 inch block. How can I not lift the front end if I have the 4.5” kit like you said? Sorry - I’m new this lifted truck scene and am just trying to get my bearings..
If you do in fact have the 4.5” you can lift the front another 2”, however if you have the 6.5” you can’t. The 4.5” does come with a 4” block but it’s possible someone swapped it out for a 5” block or that you have the 4” block PLUS the stock 1.25” block. Check to see if you have stacked blocks and also get your fender measurements
4.5" Zone
4.5" Zone
No stacked blocks..
Fender height from ground is 45.5” in rear and 44” in front. 35” tires
No stacked blocks..
Measure the front shock spacer
4.5" Zone
4.5" Zone
6”
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 173 Guests (See full list)
