What uca’s? Some of those 4” kits I posted earlier that come with new uca’s still require new wheels cause they will still rub on factory wheels with bigger tires
Get a Zone kit with perhaps FTS UCAs and stocks might work
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
17 minutes ago, chrispassas21 said:
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
Are they uniball and do you have any pics? What size tires?
BDS w/stock 20s
4.5" Zone
Thats also a 6" lift .... NOT the 4.5" lift.
Sent from my SM-N950U using Tapatalk
Do you know if 0 offset would clear on stamped steel uca’s?
I have stamped steel arms as well. No issues with my setup/no rubbing.
If you're in that much of a hurry to prove me wrong then at least take the time to post info with the same lift height in question. [emoji108]
Uniball with the stock 265/65R18 duratracs .....I believe that’s the tire size. Whatever the midnight edition comes with. What kind of pics do you need?
Just want to see what the truck looks like with that height on stock wheels and bigger tires.
3f8c15b353d76d9ee3a1ae193096414f.jpga757f7a226b3faaef93ace37d6e68ad0.jpg8dba16632a790b01c8d51d6432334d6a.jpg
I plan on going with bigger tires when I need to get new ones. Probably 33’s maybe 35’s not sure yet
It is LITERALLY the SAME kit. Different struts and blocks are the ONLY difference .
Do a little more research and i won’t have to prove you wrong, you’ll do it all on your own........
4.5" Zone
d7b2b691b502b77397be5b8e056dc436.jpgZone 4.5” on stocks (same as bds)
4.5" Zone
Looks really good. Thanks for the pics. You’ve got quite a bit of cash in that thing!
Thank you! My very first vehicle purchased brand new at 19 years old! I’d say I have around $5k in parts on it.
It is LITERALLY the SAME kit. Different struts and blocks is the ONLY difference .
4.5" Zone
If it's literally the same kit t hen why is it a different brand name?
If it's literally the same kit t hen why is it a different brand name? Sent from my SM-N950U using Tapatalk
Research Zone/BDS, it’s the same company.
And i said the BDS 4/6 are literally the same kit, as are the Zone 4.5/6.5. I did not say BDS and Zone are “literally” the same kit, although they are EXTREMELY similar
4.5" Zone
Zone and BDS are sister companies both owned by Fox. Their kits are ROUGHLY the the same.  If you want to get technical, BDS comes with top of the line struts and shocks, whereas with Zone those are add-on options.  BDS also has a no questions asked warranty on all of their parts, Zone has a limited lifetime warranty.
If you're going by kit, the BDS 4" and 6" kit are the same.  The only difference between the two are the height of the steering knuckles, and the spacers (to keep stock geometry). So really, same parent company, roughly the same warranty, and the same parts (with the exception of BDS's struts and shocks).
And obviously the price.  BDS is about $800 more expensive.
Edited by FootballCoach53
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
