8 hours ago, cubangt said:
got the 6.5" Zone with add a leaf and the upgraded shocks...didnt have time to do the install over the holidays, so we will have to see when i can work on it. will eventually post before and after pics of the truck once i get to do it.
that's going to look nice!
No good, the kits do nothing for the TRE or lower BJ angles.
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
On 11/14/2017 at 3:49 PM, Criscone said:
Zone 4.5 installed finally!
Wheel and tire specs? Looks great
4.5" Zone
Ah okay. Looked too good to be true but I see so many companies offering the kits I wasn’t sure. I like the zone 4.5” but really want to run my stock wheels and you can’t on those
On 8/10/2017 at 8:26 PM, jimmyboy8301 said:
both kits are great and they are the same company. Zone is the more "generic" kit which utilizes the stock struts/coils whereas BDS has replacement struts or fox coilovers, although you can run fox with the Zone too. (Fox owns BDS and Zone)
I have 33s on the Zone 4.5
Holy ballz that white truck looks good. 20x12? -44?
22x10 -25
4.5" Zone
You CAN run stock wheels depending on which control arms you have.
4.5" Zone
Thanks! Only thing left is spacers for the rear.
20x9 with a 0 offset
33x12.5x20 tires (305/55/20)
XD grenade wheels and falken tires
4.5" Zone
I have the stamped steel :/
23 minutes ago, FootballCoach53 said:
Alright.... last question about the 4.5" kit.... will I be able to run 35s without having to do extra trimming in my inner wheel well?
I had to do so with 33" so yeah, 35" will definitely require trimming with a 4.5".  I didn't cut but, did zip-tie.
Do you know if 0 offset would clear on stamped steel uca’s?
What is your wheel/tire set up that you had to trim a 4.5" kit with 33s?!
4.5" BDS
295x55/12.5 Nitto Grappler
KMC XD "Buck" wheels
20x12
-44 offset
There was just enough contact to tie the liners back.
Edited by AGMthing
    President Roberto
    President Roberto
  • Who's Online   3 Members, 0 Anonymous, 1,068 Guests (See full list)
