What uca’s? Some of those 4” kits I posted earlier that come with new uca’s still require new wheels cause they will still rub on factory wheels with bigger tires
Get a Zone kit with perhaps FTS UCAs and stocks might work
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
17 minutes ago, chrispassas21 said:
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
Are they uniball and do you have any pics? What size tires?
BDS w/stock 20s
4.5" Zone
Thats also a 6" lift .... NOT the 4.5" lift.
Do you know if 0 offset would clear on stamped steel uca’s?
I have stamped steel arms as well. No issues with my setup/no rubbing.
If you're in that much of a hurry to prove me wrong then at least take the time to post info with the same lift height in question. [emoji108]
Uniball with the stock 265/65R18 duratracs .....I believe that’s the tire size. Whatever the midnight edition comes with. What kind of pics do you need?
Just want to see what the truck looks like with that height on stock wheels and bigger tires.
3f8c15b353d76d9ee3a1ae193096414f.jpga757f7a226b3faaef93ace37d6e68ad0.jpg8dba16632a790b01c8d51d6432334d6a.jpg
I plan on going with bigger tires when I need to get new ones. Probably 33’s maybe 35’s not sure yet
It is LITERALLY the SAME kit. Different struts and blocks are the ONLY difference .
Do a little more research and i won’t have to prove you wrong, you’ll do it all on your own........
4.5" Zone
d7b2b691b502b77397be5b8e056dc436.jpgZone 4.5” on stocks (same as bds)
4.5" Zone
Looks really good. Thanks for the pics. You’ve got quite a bit of cash in that thing!
Thank you! My very first vehicle purchased brand new at 19 years old! I’d say I have around $5k in parts on it.
It is LITERALLY the SAME kit. Different struts and blocks is the ONLY difference .
4.5" Zone
If it's literally the same kit t hen why is it a different brand name?
If it's literally the same kit t hen why is it a different brand name? Sent from my SM-N950U using Tapatalk
Research Zone/BDS, it’s the same company.
And i said the BDS 4/6 are literally the same kit, as are the Zone 4.5/6.5. I did not say BDS and Zone are “literally” the same kit, although they are EXTREMELY similar
4.5" Zone
Zone and BDS are sister companies both owned by Fox. Their kits are ROUGHLY the the same.  If you want to get technical, BDS comes with top of the line struts and shocks, whereas with Zone those are add-on options.  BDS also has a no questions asked warranty on all of their parts, Zone has a limited lifetime warranty.
If you're going by kit, the BDS 4" and 6" kit are the same.  The only difference between the two are the height of the steering knuckles, and the spacers (to keep stock geometry). So really, same parent company, roughly the same warranty, and the same parts (with the exception of BDS's struts and shocks).
And obviously the price.  BDS is about $800 more expensive.
Edited by FootballCoach53
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 3,061 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
