What tires are these ???????
Nitto Mud Grapplers.
Had them on an old truck. Great off road. Wear FAST on pavement. Look amazing though.
Yeah I had a set of Mud Grapplers on my 84 K20, they wore out fast, were loud as hell on the road, but unlike Texas Husker I thought they sucked off road. I wasn't impressed at all… Certainly not worth their cost…
It was the only "off road tire" I've ever used so I don't have a good comparison knowledge base, but they did what I needed them to. And yes, they were annoyingly loud on pavement. Sounded like a plane was following me at speeds over 25. :lol: Cost was pretty up there, but that was 7 years ago I ran them.
a buddy of mine had these on an old Dodge single cab short box that he had, it had a 13" (10" suspension and 3" body) lift and they were 40x15.5x20.
saying those tires are "loud" is certainly an understatement. They were obnoxious haha.
And they do wear very quickly, he ended up getting a second set of tires that he would change out that were more pavement friendly since it was his Daily Driver.
Edited by Mike1220
What wheels are these ? Eagle Alloy 531 ?
These wheels will be for sale soon. Going back to stock.
Just back to stock wheels or back to stock height? Why the change?
Just stock wheels. I think these wheels are awesome. I just like a more stock look.
I hate to bring this up again, but I am still having trouble with my stabilitrak kicking in when I make sharp turns at normal speed. I have had the alignment checked and set to factory specs and had the steering angle sensor re calibrated back to zero. The thing is i don't think the factory alignment specs will work as that is for stock suspension. Now that the truck is lifted, it will be slightly different. Can someone who doesn't have an issue and has the Zone 6.5" lift kit installed post up their alignment specs that were used? Usually you will get a printout of the alignment. The specs are in the back of the Zone kit manual, but i have been told that is stock. The toe may need to be tweaked. Thanks.
Have you been able to figure out the issue with this one? In order to use the rim and tire combo I want without possibly running into issues with hitting sheet metal behind the fender liner I may have to go with a Zone 6.5 instead of the 4.5 lift. I'm curious to see if anyone has been able to figure out the stabilitrac i issue before I pull the trigger on the 6.5 this summer.
Funny you bring this up. The issue only has occured for me radomly. It actually happened yesterday and I was kind of fed up. I read on a Toyota lift forum that a guy was having the same problem. He actually found the issue with the yaw/lateral accelerometer sensor. He found it in his truck under the console and shimmed it at a forward sloping angle with some washers. He claimed it solved the abs/stability control problem.
Now if I could only find the sensor in our trucks I would give it a try. I just ripped up the console and found a module mounted to the body underneath. I unplugged it and turned the ignition on. The stability track and air bag lights came on and indicated service. I then googled the part number and it says it is the airbag control module. I kind of thought it could be as the plugs were yellow. So now back to locating the yaw sensor. I looked under the seats and thought it could be under there somewhere but not really wanting to remove the seats.
Edited by badchevy
I would think it would be somewhere near the center line of the body. Not sure why but something tells me it would be along the center line and not under a seat. Could be wrong though. And have you tried asking someone at a dealer? They may be able to shed some light on its location.
Hopefully you can find it and it will help solve the issue! Would make me a happy camper if it was figured out by summer [emoji4]
I am in the process of getting a 6" BDS coilover lift and 35" toyo mt's on 2015 silverado. I was wondering if anyone has had any issues with gearing or more specifically needing to re-gear after swapping up to a 35" tire? Anyone with this set, is the 5.3 beefy enough for that size. I am used to diesels and this is my first gas truck so I'm just not sure what expect.
My dealer had a sick looking ltz today... I don't think I could ever do it lol. I also couldn't justify laying 69k for a pickup
Edited by 20Bowtie14
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
