I run 33 1/2 with 20s on 2.5 rough country level kit
What are the wheel and tire specs? Any rubbing issues, also any pics?
I have a 2014 Silverado WT reg cab std bed 4wd. I'm going to put a set of 33x12.50x20s on some 20x12s with a -44mm offset. I'm pretty sure a 6" lift will get the clearance I need. However, I'm interested in a better than factory ride. Low to no maintenance. Good geometry everywhere...drive line, steering, suspension, etc... Good build quality. The two least important issues are ease of installation, and cost. None the less, low to no cutting/grinding would be appreciated. What is the best kit?
Added ReadyLift 2.50" front and 2.25" rear blocks with BFG TA KO2 tires. Live the look and higher stance. 275/60R/20 tires.
Any have pictures of a 3" body lift on the 14s? Curious of the frame hang. Have had a 6" suspension lift since the beginning of the year but need to post pics for y'all still
I have 6" suspension and 3 body. The frame hang isn't bad if you cover it with steps that mount to the rocker panel
Can you post some pics of your truck?
Do you have any shots that are like chest or waist height from the side? curious to see how the gap looks. but it looks like you have gap covers, is this true?
Also, how did you run the bull bar mounted to the frame with the body lift?
What wheels are these ? Eagle Alloy 531 ?
LRG 104 20x9
Anybody? I figured I'd at least get some unsubstantiated opinions...
No cutting for suspension install is not going to happen. I have 5" lift x12 -44 equivalent 33x12.50x22 and rub cab side fender pretty good at max lock. 6" lift MIGHT give you clearance but I can't say for certain. With price out of the question most would steer you towards FTS or BDS...one thing you have to consider on the lift is if it increases the track width. There is no way x12s will work on 6" lift if you go with a lift that increases track width Edited by baggedlvintegra
What's your wheel/tire setup specs?
Fuel wheels
offset unknown
Nitto terra grapplers 33 1/2s
2.5 rc level
