any body here install a long arm setup? I am curious as to how the ride quality is and how much it affects the towing capabilities.
I know this may sound funny but has anyone with their lifted truck after a while feel like its tiny or doesn't look lifted? Ive had mine for a bit now and to me it feels like a stock truck and doesn't seem all that high to me lol maybe its cause I'm 6'3" idk
Been driving lifted trucks since I was 19 and can confirm they feel normal now. Stock height are low riders.
Same thing with lifting weights. You always feel like youre never as jacked as you should/could be
Yeah. It's a terrible disease. I want 37s next. Then I'll want 40s. It doesn't stop. Lol
Ok boys need some help!
I'm looking at putting the performance accessories 3" body lift kit part#10293, but I can't really find any reviews and was wondering if anyone is running it. I'm adding it to my RC 2.5 level kit cuz I wanna run 37s:). Please help on if on this kit.
http://performanceaccessories.com/vehicles/96-2014-2015-chevy-silverado-1500-3-inch-body-lift-kit.html
No cutting for suspension install is not going to happen. I have 5" lift x12 -44 equivalent 33x12.50x22 and rub cab side fender pretty good at max lock. 6" lift MIGHT give you clearance but I can't say for certain. With price out of the question most would steer you towards FTS or BDS...one thing you have to consider on the lift is if it increases the track width. There is no way x12s will work on 6" lift if you go with a lift that increases track width
Thanks for the reply! While cost is not an object, I do not want to pay more for the same or less. At first, I was kind of scared of the RCX, but they have a lift that does not use knuckles. They say the 7" will clear the 33 x 12.5. They said it would clear a 35 if I was not using the 12" wide rims. Any thoughts on a smooth ride shock?
    • Jumped up 15 cents yesterday. $4.15
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
