Cracked Dash 2008 Silverado LTZ CC VMax
If this was a detailing problem, the crack would not be on the same position on the dash on hundreds of vehicles! Please put your info on the legal firm posted! Also, GM has known about this problem since 2006.. As I mentioned! Call GM corporate offices and inquire as to why your dealer isn't replacing your dash for free!
My repair is being done tomorrow!
  • Replies 97
I am contemplating this one
Ryan
No cracks yet.................................I too, like this solution if GM were to give me the cold shoulder. Surprising the LTZ version is less $$$ and so MANY colors to choose from. I would try and match the A pillars/headliner rather than go black.
my 07 has a few cracks and getting worse......I don't think it is worth 400 or so bucks to replace so may just get a dash cover (yes they are ugly)
I had an 09 Avalanche with same dash cracking issues and ended being fix by my local dealer for around 250 on my end. It seemed worth it to me to get it done, looked like it would be very labor entinsive to remove that dash.
Hey davecaris,
Glad to hear your dealer worked with you and fixed your dash! Please feel free to reach out to us via PM in the future if you have any questions. We're always happy to provide assistance.
Sincerely,
Eddie A.
GM Customer Care
I found the same cracks on my '10 Sierra dash over a year ago. Already contacted dealer and GM Customer service reps (April 2013) here only to have dealer tell me that I was stuck for $200 of the repair costs. No thank you. I'll drive it like it is and will remember the "customer service" when it's time for the wife a new vehicle. Pretty sad when a 3 year old dash cracks and the dash in my 1998 Sierra looked like it was brand new when I traded it in.
I do not have any dash cracks on my '06 Silverado, but the dash surface next to the windshield feels a bit sticky to the touch. Is this normal for the GMT800 series? I just installed one of those velour dash covers.
It's most likely the velour
I have a 09 Sierra with two cracks on the dash one over by the airbag and the other above the driver side, truck had mostly be garage kept.
  • 1 month later...
These dashes are made from poor material ,my 2007 sierra is cracked all the way around air bag and is mostly garage kept. Maybe a continuing post on Facebook would make GM repair this safety concern!
Hey 2kflhr and everyone,
We're very sorry to hear you've developed cracks in the dashboard. We'd be happy to connect with you preferred dealer and explore any available options for assistance. Feel free to reach out to us via private message if this is something of interest. Please be sure to include your full contact information, VIN, current mileage, and the preferred dealership.
Sincerely,
Eddie A.
GM Customer Care
Eddie A.,
Sent a pm with my info. 2008 Silverado with dash cracks on both upper corners of the airbag cover and another crack with a hole in it (about 1.5 inch x .5 inch) over the instrument cluster.
There is a safety concern about sharp plastic breaking off during an airbag deployment. I'm the original owner at 94,000 miles and previous owner of 1992 and 2000 Silverados purchased new.
    RyGuy43
    RyGuy43
  • Who's Online   2 Members, 0 Anonymous, 476 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
