Hi everyone! I'm new to the forum and I'm about to order a new 2014 Sierra. What's everyone that's lucky enough to own one seeing in the fuel mileage dept? I'm particularly interested in the city mileage since I have about a 4 mile drive to work and don't do much highway driving. I have a Trailblazer SS currently and I'm getting about 11 MPG. Hoping for a decent improvement and to get at least what the EPA rating is for city driving (16 MPG). However, I know the EPA estimates aren't always the most accurate. Thanks in advance!
609 miles on odometer (about 200 hwy, 400 city) & DIC shows 16 MPG average (that's with AT tires, level, & front air dam removed)
I personally would like to know what the highway economy is like, I do about a 1000 miles a week almost all highway
Holy crap! :blink:
Sent from my SCH-I535 using Tapatalk 2
I bought my truck & then drove about 200 miles of interstate to get home. I averaged 21-22 MPG, going 77 MPH, with an outside temp between 85-90 degrees.
Thanks Motomedic, that's the kind of real world numbers I was hoping for
Those #'s are from 2WD with the factory "nose dive" angle. If you really wanted to squeeze every MPG out of her you could drop the rear a tad, add a bed cover, and even go so far as the adding close out panels under the truck (simple thin sheets of aluminum mounted similar to skid plates but the full length of truck frame). Though depending on how you use your truck, those might be unrealistic.
I was quite surprised by the AFM fuel mileage program in this EcoTech 5.3L. it will really help this trucks fuel mileage I was seeing 20-21.9 at a highway speed of 60-70 mph of a mix of rolling hills and bridges.The test drive was on the 2014 Chevy Silverado 1500,4wd,5.3L,3:42,standard bed and I know a lot has been said that DIC fuel mileage systems are not accurate,but this software tends to tell a different story,of being very close on estimates,EPA new rating system has been very close on cars and trucks this year across the board a mix of real and track roads(I see them from time to time in LA here cruising are freeway systems heavy traffic and wide open interstates.In the end I have decided to buy a 2014 Chevrolet Silverado 1500 LTZ,Z71,6.2L,3:73,Max trailer packaged truck.This is a fair stone's throw ahead of my current pickup,performance.The 5.3L was very responsive to throttle and would run up or down the gears in nano seconds,without me even looking down,I would not know it because the linear shift response was quite sharp.This truck was all about fuel mileage this incoming Gen powertrain is a very big jump for GM. The E85 fuel hp/torque figures' were impressive.A very light 1/2 ton truck and very responsive with the electronic steering at the helm moving within the lane is all about eliminated this was running 265/55/20's.They say that GM will release a 5.3L Max Trailer tow which will include the 3:73 axle for this truck that would hit mileage a tad but performance will put a smile on any Silverado owners face that I know.So I wait for the ordering giants at the General to load the 6.2L option and all the goodies that make this truck again in my book a world class truck along side it's big brother the Chevrolet Silverado 2500/3500 Duramax diesels.
Edited by Bravo1
On my way to New Orleans, I decided to check how much my modifications had decreased my MPG. The big three I did that affect gas mileage are removing front air damn, raising front end 2", and installing larger tires. (the numbers below for Modded Truck have been corrected for increase in tire circumference)
Stock truck: 21+ MPG @ 77 MPH (outside temp 85-90 degrees)
Modded truck: 18 MPG @ 77 MPH (outside temp 90-95 degrees)
So my modifications cost me 3 to 4 MPG at interstate speeds. Well worth it to me! :thumbs:
i do anywhere from 600 to 1000 a week... i have car that i use as my DD... the money i save in fuel pays for the car.. i get about 40mpg on the highway
Would think most of the loss is from the tires?? Did you use the DIC for the #s and/or check it at the pump?
i have 1300 miles on my 4X4 LTZ Z71 5.3L, i have a 15 mile highway drive to work with a stop about every 2 miles i drive, if I baby it I get over 20MPG. The DIC has an MPG readout for every 25, 50, or 400 with your average and best mileage reading, my best 25 miles MPG is over 26, don't know how this figures but it sure sounds good. Use to have an 09 Acadia which i never got anything better than 21MPG highway.
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
