For those of you who have installed a 2nd set, how did you attach them? Did you drill into the bed or did you use something like 3M VHB tape? Thanks!
I cyt through my bedrug and then screwed into bedside.
Thanks. Did you do anything to the holes to prevent paint damage and rust?
OK two questions from reading this thread.
1. For a second set of lights how do you power them? Plug into the same harness by the spare tire?
2. For adding a second switch for the lights is there a really simple and neat way to get this accomplished too?
1) no, you can only plug one harness into that plug. I went ahead and spliced into the original lights. Did that right behind the tail lights so it would be easy access.
2) I'm not sure cause I haven't added a second switch.
No I did not. I just used a self tapping screw.
Didn't really think to do anything to prevent rust or paint damage cause I wasn't sure what to do for that.
Edited by Mike1220
Just installed my second set of OEM LED lights under the bed rail "truck came factory with one set". Also just got my truck back from installing a Line-X bed liner with sealer. Second set makes a huge difference and even outs the light in the bed.
Before
Before 2
After
After 2
How did rig up the second set? Did you just splice into those ones that were already installed?
Rick
Rick
Yes, I spliced into existing set or wires behind the taillights. Install was very easy, I solderer the spliced wires together and then used heat shrink to seal the wires.
I too spliced two GM sets together on my 2013. I soldered the red and black wires together, and used heat shrink wrap to seal up the splices. Worked very well..
Edited by 2013sierrasle
Yes tis is the way to go... I also did this very same thing... many have. Works great.
I too spliced two GM sets together on my 2013. I soldered the red and black wires together, and used heat shrink wrap to seal up the splices. Worked very well.. 1010545_742451065767983_141971304_n.jpg
How did you get the heat shrink tube on the splice? Or did you use heat shrink tape?
I slid the heat shrink tube down the wire prior to soldering, then after soldering the connection, slid the shrink tube over the connection and heated it up.
I'm guessing you disconnected the existing wires to be able to slide the shrink tubing on? Sorry for my dumbness lol.
For those of you that have spliced in a second set of oem lights, are there mounting points already from the factory for them? How did you mount them?
If you are mounting a second set forward from the original location then you will have to drill your own holes. just be careful and use a sharp drill bit.
Ok sounds good just gotta figure out if I really need the second set. I have a tono cover am not sure if one set will do it. I don't need it to be lit up like the 4th of July but I'd like enough light to be able to see to the front
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
