I did the 2" level with an eBay kit for $37 made from aluminum. Worked out well. I am trying to figure out what wheels and tires would look best on this truck now.
Edited by J.Wilhelm
Anyone running 305/55r20 on aftermarket rims on a 2.5" level?
Is that a 2" level?
its a 21/2" front and 1" rear ....got done at the dealership for free because my brother bought two other vehicles from them
Edited by superchuck
It's a very popular size on here. Lots of people have it. Grab a cold one and peruse through this thread. Lots of good looking setups.
Hey I just saw your truck posted on bks built trucks on Instagram and it looks bad ass. I've read this whole thread and I have a couple questions for you, or just anyone who can help. I've been in the process of ordering those same rims and tires for my 2014 white crew cab all terrain and I have the rough country 2.5" level installed on the front already. What is your offset on your rims and what are the tire specs, does it rub and did you have to trim. I want to try and fit some 305/55r20 trail graps on those rims maybe even a 20x10 with a negative 12 or 18 offset or whatever they offer in this rim but I haven't seen anyone do it with this same set up yet so I thought Id stop reading and waiting and just ask. Thanks for y'all's help
you wont fit a -12 or -18 offset with out major rubbing
I want to do a leveling kit on my 4x2 but I definitely don't want the "offroad" look...just a nice level stance (maybe a tad lower in the front). I personally hate the stock LS2 tires on my 20s, will the factory 275/55/20 look odd once the level kit is installed? I really don't want a wider tire, but a more aggressive tread pattern that still rides smooth would be great. I wish my truck came with the Wranglers, I think that's a good looking tire...just didn't know what you guys recommended brand and size wise.
I don't have 20's but my truck it levelled 2" up front with the stock 18's I think it looks ok. I mean I'm not rushing out to get new tires…
I had Cooper AT3's on my last truck and liked them a lot, they are not super aggressive, but were a lot more aggressive then stock. Plus they performed well off road…
I went with the Skyjacker 2 inch leveling kit since that is what the chevy dealer had as part of the closing deal on both of my 2014 Silverados. The trucks look so much better without the nose dive to me.
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,245 Guests (See full list)
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
