More pics. I'll take more when I'm home. If I didn't put the block it would be saggy.
I just left back to camp for 3 weeks. Although it looks level in the pictures it still has a slight rake. Which I wanted. It's not noticeable at all, but it is nice when you're pulling something not to have it so bagged out. I removed the stock block and got the 2" installed. That's the route I would go
Hmmmm maybe I will. Thanks!
'14 K1500 Denali, 2" RC under coil front only. No mod to rear, stance 39/39 F/R with 295/55/R20 Toyo ATii Open Country and I'l likewise pleased with the result, ie. just enough stance and rubber all around rides and drives perfect.
Finally getting around to doing my Double Cab Z71, but wanted to ask a few questions.
First, being that the Double Cab's weight sits more to the front, and the Z71 rear end seems to be a little stiffer and sits higher, should a Rough Country 2" front level still leave me some rake?
Also, if I go with the 2" level, and go with a LT275/70R18 tire (and have the computer reprogrammed), am I going to kill my MPG's?
I put Lt 275 70 18's on my z71 without leveling, doesn't rub stock, and I lost about 3 mpg. Edited by 20Bowtie14
2" will still leave you some rake on Z71. With 275/70R18 on mine, I am averaging 16 to 16.5 mpg. Don't know ow what it was before as I installed the level and tires the same day.
2.5 ready lift with 2 inch block in the rear. 33x12.5r20 toyo mts. Rub at full lock, but not enough to make any adjustments. Love the look, changes the truck. Recommend the level and tire combo to anyone.
Wow, that looks great. Where is the rubbing? Is it on the body or frame / suspension / swaybar?
Sway bar. That's It. And thanks man. It's a perfect setup for me
2.5-inch RC leveling kit with only the front kit installed. Stock rear block. Sits really nice and is visually level or just a smidge up in the front... but I like/wanted that look. Tires are 275/70/18s with no rub in any situation.
  • Like 9
Looks great! Are those factory 18" wheels? What brand tires? I just received my RC kit and can't decide what tires to put on my factory 18" wheels.
Can you post some pictures showing the tires from the front, side, and rear? I am looking at the same tires for my Denali.
Hello, I read and reread this topic and have a question...
What is the difference, if any, of the leveling kits that use the spacer on the bottom verse the one that uses the top, "U" verse the 'donut'?
Is one 'better' than the other and why kits that have both?
Thank you.
Mine is finally done! After months of research I went with the RC 2.5" level kit front only, stock rear block. 20"x9" Fuel Nutz w/ +1 offset, 33x12.50x20 Toyo M/T tires. No rubbing, No trimming, yet anyway. It is perfect for me. Just what I wanted.
  • Like 11
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
