You lost that much jumping up a 1/2" in tire size? Truck does look great thou…
It has more to do with the weight of the tires and the flatter stance. I notice it spends a lot more time on V8 mode.
Are you calculating it correctly for the new tire size? or going by the display?
Hand calc. The difference tire size only makes a 1.6% difference so it's basically negligible.
I've got a 6" lift and still get 17-18 mpg highway (downhill with the wind.... ;) ).
No but really I was surprised I still got that good of gas mileage. My 2010 gmc sierra SLT got 14 mpg with a 4" lift. My 2008 silverado with a leveling kit got less than that, granted it was a 4.8L.
Anyways. Carry on.
I had a Zone Off-road 2" level kit put on my 2014.
It measures 38.75" from the center of both wheel wells to the ground front and rear.
I also added a set of Timbren SES rubber helper springs to the rear to prevent too much squatting with a heavy load in the bed.
I am pleased with the new look it gives the truck.
Getting ready to drop the back, anyone just pull the blocks, looks easy instead of shackles?
I did I like it much better, and only took 20 minutes lol.
Before
93F2DF96-4D54-4D4F-88FF-D4875663AD63_zps
After
C17BCBC7-ECD9-4999-A012-73F9D25320D3_zps
Before
After
Thanks that's what I thought.
Yes they are pretty easy.
I'm going to order the 3.75" combo kit tonight.
Does anyone on here have the body kit part done?
Also does rough country do a members discount?
I went with the zone 1.5" body lift and 2.5" rough country. Gave 4" instead of 3.75"
I'm happy with the zone body lift. After there were a couple other people on here that did there's too; they were happy with it also
This is the setup, 4" combo, that I'm eyeing. Is your body lift RC as well or Zone seems to be the popular one. I'd like to do Toyo AT II's in 295/70/18, on my stockers for now. I've seen one truck with this on a 4" suspension and it works, mostly, offset caused slight rubbing. TIA.
I have zone body lift. I went with them because I've had a zone BL on a past truck and like it.
Are you wanting to go with a 4" suspension and a 1.5 body lift, 5.5 total? if so you shouldn't have any problem clearing that tire.
Thanks. I was looking at doing rc 2.5 level and zone 1.5. Total of 4. Not sure if these tires will make it. Wanted to run my stock 18s, but if a different offset is required to get away with the 295 70 18s, I will either go that route or try a smaller size.
Ok thats the set up I have
I think as long as your close to stock offset you will be fine. I'm running a -12 offset and 305/55r20; if I would have went closer to stock offset I could have fit a larger tire
Here is all the info when I did mine.
http://www.gm-trucks.com/forums/topic/155646-wheel-offset-tire-combo-after-lift/
Good to hear. I actually like the stock Z71 18's. Might powder coat or change them, but I like the design. All I need to do is put some more miles on now and wear out the SRA's. I can get clearance from "the bank" to get larger tires if I use up the factories first. 15xxx and counting. They look like they are wearing down quick at this rate though. I was trying to find your thread ealier. There is a lot of good info in that one. Thanks again.
Yeah I don't know whos bright idea it was to move it out of the 2014 section when we have all these other similar ones in here but oh well. I've had quite a few PM's asking me if the thread was deleted
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
