I'm running 276/65R18 Terra Grappler G2s that the dealer put on my truck when I bought it without a level....no issues. Some are running the 275/70r18 and the 285/65R18 without a level, but that would be pushing it.
I had 285/65/18's on mine without a level and it was fine, but it was really close to having to trim some stuff.
I have 275/70/18's with a 2" level on right now and haven't had any issues.
Ok 17" Method MR306s wrapped with big at/ko2 285/70/17s with procomp zx2108s for what they call 2.75" of lift.
Edited by Csjumper2003
Funny, know one has tried this set up, maybe someone that has will chime in. Either way I plan on running an RTX rim, not stock. It's just it will likely be another few weeks too a month before I can post pics, I'm waiting for the spring weather too hit. Thing is I plan too purchase my set up this week.
Know of a guy running 2 inch on his Silverado as well with 275/65/20 and hasn't rubbed a bit since. I don't know much about this kind of thing, but figured an inch difference in diameter and half inch on the lift,things should equal out,maybe,lol
I'll post pics as soon as the snow goes and it's giving +8 Celsius tomorrow
Until then any info relating will be helpful.
Thanks
Thanks
I finally got my 2014 last weekend and quickly realized that it needs a leveling kit. The center of the back wheel well measures 39 1/4" and the front is around 37". I'd like to find a leveling kit that doesn't mess with the back at all, anyone have any recommendations?
i recently just bought the 2.25 leveling kit from supreme suspensions on my 15 GMC Sierra 1500. awesome product
Is there a thread on 14+ leveled trucks with body lifts? I thought I saw one awhile back but I can't find it now. I'm ordering my body lift kit and would like to see some pics. Which should I get? I did see the Zone 1.5" but that the only one I saw.
I have one quick question. I'm wanting to install a leveling kit on my 2014 crew cab. I'm looking at the Rough Country 2 in. because it's on sale right now.
My question is is that all I need to level my truck? I'm new to the truck modification world just making sure I'm doing everything right.
I have the 2 inch RC level on my truck and I sit 3/4 of an inch higher in the back than in the front. Every truck is different but I am happy with the way mine turned out. I didn't want to be super nose high every time I put something in the back or pulled a trailer so it worked out well for me. Best way to get want you want in height is to measure your wheel well height and decide how much you want it to raise the front, then go from there. (1.5, 2, 2.25, 2.5 etc.) You will also have to get a front end alignment after installing any lift to prevent premature tire wear. Here's my build, hope this helps..
http://www.gm-trucks.com/forums/topic/181879-my-new-2016-gmc-sierra-ccsb-z71-slt/?view=findpost&p=1742013
Also make sure you get an alignment after you install the level
Do I want the aluminum or the steel? Any difference in one vs. the other?
Well the option is there depending on if you have the aluminum or steel control arms. If you have a z71 it should be aluminum control arms. If your not positive go out and take a magnet off your fridge and see if it sticks or not (will not stick to aluminum). The only difference is the length of the bolts between the two. (the bolts for the aluminum control arms are longer) Hope this helps.
Anyone running the zone 2" level? I'm not sure how I feel about it not being metal. Also looking for some input on whether to go with a 2" or 1.5". I want a small rake still for when i do tow, but mostly level. From what I've read it seems like a 2" would be good, but I have also heard from some the a 2" made their truck slightly higher in the front.
I realize that this question has probably been answered in the 200+ pages of this thread but i couldn't find it in the 30+ pages i looked through.
I was wondering if i could run 295/55/20 toyo AT2 with fuel mavericks and 0 offset with no rubbing on my 2015 sierra crew cab with the 2 inch rough country leveling kit?
Or possibly the toyo MT on the same setup with no rubbing
So if I have just a regular 2wd I should get the steel?
Zone 2" level
    Enduro73
    Enduro73
  • Who's Online   2 Members, 0 Anonymous, 1,648 Guests (See full list)
