Good Lord, and don't put any weight in the bed either, it may change the geometry of the suspension.
The described her tires as large and could potentially be harmful to her drivetrain as well.
But....275/60/20s are only slightly larger then stock. Lol and she has a level not a lift kit.
Sent from my Note 4 on Tapashit
Speak for yourself
This is the crap i have to deal with right now. As soon as they saw the level they called my girl to pick up her trucl because thats what caused her leafsprings to squeek like crazy.
I remember years ago when my cable provider wouldn't service my modem because I had a wireless router. The same provider now supplies wireless routers. I think your dealer is out of date in meeting customer needs. Dealerships in my area have progressed from bad mouthing level kits to supplying and installing. "Lead, follow or get out of the way!" You should take your service elsewhere. Maybe it will help promote change!
It helps to know what you are taking about as well. They take advantage of my girl cause she isn't truck savvy as i am. Wait till i get home!!! Haha
And i know man i had to deal with that yesterday with my ISP. I finally got fed up over the phone amd said "look lady i have 2 college degrees in computer hardware and networking.... The problem is on your end!!!" finally sent out a tech and turns out it was something they changed om the modem (that i couldn't get into... Port blocking) my router is worth x3 what their modem is lol
Edited by Txjose
Wow, this definitely changes things lol.
The dealer I've been talking to is not the one I purchased the truck through. I bought my truck 4 hours from here but they were very easy to deal with, I guess I'll maybe be making the 4 hour drive.
Looks great! I believe a 1.5 to 2 inch level is a perfect stance for these trucks. The wheels look great as well, however I think the size would be too much of a power drain on my 4.3!
Who all is running a 1.5"? I think that's what I've decided to go with and still have about 1/2"-3/4" of rake.
I plan on installing a 1.5 but I was figuring on being left with an inch of rake.
After measuring mine 2" would be about perfectly level. That's why I'm leaning towards the 1.5"
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 453 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
