What are the differences between the two part numbers?
One is front the other is rear
Just leveled it this past weekend, much better!
RC 2.5" level upfront only.
Thanks. From what I know all I need to level are the front shocks. Which part number are those?
The part number beginning in 24 are the front.
Edited by Imperial91
What is the specs of tire/wheel size and offset?
2015 silverado 2 inch shackles in the rear 2.5 leveling get kit in the front
So you dropped it 2" in the rear and lifted it 2.5" in the front? Why?
Rims are Method Mesh 17x8.5 0 offset 4.75 backspacing
Tires are Toyo Open Country ATll's 285/75r17
Sent from my iPhone
Because that's what I wanted. My truck is not a 4x4 so I was not going to level the front past the 39 inches and have it look like a 4x4 when I know it's not. If I'd gotten a 4x4 then I would of just lifted the front.
That makes no sense, your truck just looks broken that nose high
That's okay if it doesn't make sense to you there's a lot of trucks that don't look right to me but to each their own. I'm not making payments on their trucks.
I simply think there is a misunderstanding. The terminology you are using sounds like you lowered the back of your truck 2" and raised the front 2.5". Is this what you meant to say?
Yeah that's what I did. The truck has a squat it just depends how the picture is taken that makes it look really squatted or very little
OK. I am also curious as to why you'd choose this look. I read your earlier posts and I understand that this is the way you want it to look. A truck that is lowered has a street cruiser appeal. A truck that has a rake looks ready for hauling. A level truck looks aggressive. A truck that is squatted looks compromised or that it is too heavily loaded. This is not a criticism, I am just very interested!
Here's another picture. As to why well I'm from California and here it's a style. What works for us might not work for others and what works for others might now work for us.
  • Like 4
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,212 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
