I really like your setup! I think I may go with this on my '14. You have a 2" level right? What brand did you go with? How much did you feel the 2" effected the ride? Thanks
2" Level and i dont feel like it messed with the ride much at all. I like it more with the level on it... but I also have the bigger 10 ply tires, which stiffen up the ride quite a bit.
It rides great though! Way smoother than my 2008 did.
Hello all
Like many I have read this until my eyes bled. Today I installed rc 2.5 front only with 275/65/r20 on 2016 slt 6.2 crew cab with std bed and z71 package. I have the 20" chrome clad wheels. After callingv 3 dealerships they are the same offset at the other 20's. 27mm. I was a little nervous about the tires but I couldnt be happier.
My initial measurements were
Front 36.5
Rear 39.75.
From ground through middle of tire to wheel well.
After was
Front 39
Rear 39.75
Results
Ride is stiffer but enjoyable and very smooth. Tires run great. I haven them at 50 psi and they move effortlessly. No real loss of power that I notice. So far I had some rubbing at full lock to the right only. I will have to check in the morning but very minor.
No regrets and love the way it rides and looks.
Hello all
Front 36.5
Rear 39.75.
After was
Front 39
Rear 39.75
Results
Hello all
Front 36.5
Rear 39.75.
After was
Front 39
Rear 39.75
Results
Hello all
Front 36.5
Rear 39.75.
After was
Front 39
Rear 39.75
Results
I also run 275/65 r20s that roll good but lowering my tire pressures to 40 made it ride better with no loss in mpg. I have read of others going lower.
Sent from my SAMSUNG-SM-G890A using Tapatalk
I have the same size and I am running 35#psi and the ride is nice. I would like a wider tire preferably but I don't want rubbing(I don't have rub now, after 2 zip ties).
Sent from my SM-N910V using Tapatalk
I am not on board with tuning yet -- even just a speedo calibration.
I went to Disney World over the weekend; I have the TA KO2 in 275/70R18 at 40PSI. I do have a Range AFM device so my V4 mode was disabled both directions. I averaged 70-75mph
Heading down from Jacksonville to Orlando: computer said average fuel economy was 16.4mpg
Heading up from Orlando to Jacksonville; computer said average fuel economy was 18.0mpg
I am fairly certain that by not calibrating the speedometer for the new 33.2" tires causes everything to be quite wrong--trip, odo, fuel economy calculations, etc? Is that correct?
I feel like they are seriously wrong because I went to Disney World not too long ago without the lift/larger tires/AFM device and the fuel usage (in terms of filling up) was about on par with my previous trip. Cash wise it didn't seem like I used all that much fuel compared to before.
Interested in your thoughts--overall I am in love with tires and the level!
Guys I'm curious on something. For those that installed a leveling kit and also installed the 2 inch rear block. Was a shock extender for the rear needed due the increase in lift?...Or does it work fine without a extender?
Sent from my Nexus 6P using Tapatalk
I had the 2 inch rear block installed on my Silverado in place of the factory and no shock extender was needed-at least that's what the shop that did the install said. The ride doesn't seem any different to me.
If you're replacing the factory 1.25" block with a 2" block, you don't need longer shocks (or extensions). That extra .75" isn't enough to make a difference. However, if you stack a 2" block on top of the factory block, or replace it with a 3" block (which is a better option), then longer shocks are recommended.
OK thanks guys. Yea I was thinking just the 2 inch right now. I think if I went with 3 inches my rear height is ~39.25 now and that would make 41-42. I don't want a rake in the truck
Had some 295/60r20 Toyo MT put on my truck this weekend. Zip tied the liner back and no rubbing besides on the sway bar at full lock. I only have a 2.5" Traxda leveling kit on the front.
BBB2E350-B994-4349-A064-87B59E63F165_zps
  • Like 5
Installed my 2.5 motofab levelling kit and added a 1" rear block on top of factory block. Within 1/8" of level
Edited by Jibroussard
Rough Country 2" leveling kit, Cooper Discoverer STT's 33x12.50x20.
Can you add more pics of your cooper tires? Also how have they held up?
Can you get a pic of the leveling block that you have in the rear? Thnx
Truck looks sharp!!!
I think i will be getting toyo MTs when i do my lift.... Only on 33s right now with a level.
I need the white handles and mirrors!!!
Sent from my Note 4 on Tapashit
Dont have on of the block on the truck as i am not at home right now but let me get a screenshot of what i bought Edited by Jibroussard
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
