295/55/20 no rub. Toyo MT. I'll upload some more pictures tonight
Following. Want to see the look
15d13a1df7841d5d10bc9e20cdf1e325.jpg06ed3407fc0e74a498ec42dd252a4a80.jpg74c980b53b5794d374a85729b13952e9.jpg4baeb1d33f5f28fa00a0f1e06abdc203.jpg
Totally sick and jealous! Can you share your specs? Kit, offset and so on
2.5 Rough Country lift. 295/55/20 Toyo MT tires. Fuel Maverick wheels 20 inch with +20 offset
Would you say there's room for 305/55/20? Or do you think 295/55/20 is pushing it? I assume there was also no trimming involved?
I don't know his name but a guy a few post before mine with the same set up on a white gmc did 305s. Ask him. ..all I know is I have no rubbing at full lock and they look sick.
Thanks bro. Your truck is definitely on point. I'll look this other cat up
Anyone added rancho quicklift or bilstein ride height? I have 2" rough country and when I hit bumps it feels like it bounces. I'm looking for a more secure leveling/lift kit that rides smooth while towing or off roading? Any suggestions
Sent from my iPhone 6
using Tapatalk
Has anyone had both a rough country and readylift leveling kit? I'm doing research on which is a better one to install. I was all for a Rough Country until I was thinking about how the spacer block is like some type of reinforced plastic. Where ReadyLift has the aluminum 2 piece set. Thanks for the suggestions. The trucks on this thread are amazing and I hope to get mine done soon. :cool:
My kit was a 2.5 lift. .5 rubber spacer on tip and the bottom was a u shaped lift that takes the shock and moves it up 2inch. I have a YouTube video posted up.
Btw it rides great with this set up....
f20fc15affb35fe9eb6848fc512db7cc.jpgd258adc0d99f1542d280f1d6d58ff7ac.jpg9c67fcd2ae0b1bb27bf0a4bd951f69d3.jpgc17fcccf059937a6c16e1e4254254915.jpg1d13fee93945c95b77dac2490f9cc0b7.jpg
Nice truck man, I'm really diggin' your setup! I want some aftermarket wheels but can't find the hear to part with the stock chrome 20's.
I couldn't help but notice most of the trucks on here are perfectly leveled or so it looks that way. Mine doesn't sit like that and I still can't figure out why. Maybe I installed the kit incorrectly? I also have a 2.5" RC kit but it doesn't sit like this one does. I didn't install the rear block because I figured it's already not leveled why would I raise the rear even more? I also still have this noise my kits making and can't figure out what it is. Makes a really loud "squeak" sound when I hit any type of bump and occasionally when I put the truck in reverse it'll make a pop sound, when I turn the wheel all the way to the left in drive and go forward it makes a really loud pop sound. Any ideas guys?
I had mine installed at a shop. They use a ton of grease on the .5 spacer on top...I know this because I went to look inside and my hand was covered in a thick black grease (truck is only 2 weeks old) as far as the popping have you re-torqued the level kit? I drove mine for 300 miles and has the same thing and once they went over the level kit and tighten everything up it went away. I have 600 miles on my lift with no noise. I'll measure tonight but before the new tires i was at 39 inch up front and in rear to to the center wheel well.
I am at no means a mechanic too. So wtf do I know... just stating my experience
Filtered
Make sure everything is torqued correctly and also check to see if the lower bolt is hitting your drive shaft, check both sides.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
