First 2014 Regular Cab I've seen at a dealer
Just looking at the Build and Price page for these little fellows and it does show avaliable leather seats. Does not show if they are heated though..... With out heat they would be damn cold on the butt!
  • Replies 59
Except you probably can't add factory heated seats like you can with the GMT-900.
Katskin have a heated seat kit that they sell with their seat covers. Then with the Katskins you could get a little more imaginative than plain old black leather. GM needs to get more imaginative with their leather interiors like Ford does! I love the Brick Red seats that you can get in Ford trucks!
For me the deal breaker would be that tiny radio screen in the space designed for the 8" Mylink. It just looks retarded, like an aftermarket kit from Crutchfield or something. With the way everything is integrated I'm not sure if you could swap it out either.
I agree. GM always does something stupid like this! You really ahve to wonder how much imagination these guys have.
I agree that it doesn't look NEAR as good as the 8 inch....but it isn't as bad when you see it in the truck.
It's much better than the standard radio in the 07-13's.....but not as nice as the 8 inch Mylink obviously !
I talked to a car stereo place I deal with all the time and the harnesses and kits are being completed now....should be out very shortly !
You still should be given the option for either radio when you buy the truck.
I still disagree with that, I drove an LT crew cab with the little radio and it looked so out of place. I kept staring at it while driving, wondering why they did such a thing. Good to hear there will be aftermarket options, it's a shame that has to be done on a brand new truck, especially when the MyLink radio is also integrated with the little screen in between the guages. I would assume an aftermarket head unit would make the audio functions in that screen worthless. Take a look at the LS Equinox with the base radio, the dash piece in the middle is different and fills up that space. It doesn't scream "I bought the base model!!"
Now here's the upgraded radio.
It's a shame the base radio sticks out like a sore thumb in the trucks.
2094FA6A-41A3-4880-AD13-D6C30D219673-279
9190BC37-54F4-40B4-8FF2-BD61A5288FC4-279
I can't say 100%, but I would be surprised if the aftermarket harness didn't work through the (gauge display) DIC just like the factory unit.
If this radio was available ONLY on the very base work truck I could understand it better than getting it on a $38,000 regular cab....don't like that one bit with no other options.
It's funny even though it is tiny it has lots of great features but the display is just toooo small.....don't know why they ever chose to even offer that radio honestly.....but it still beats the functionality I had on my 07 until I put a Nav unit in it.
I have a kid on the way now so I needed a crew cab this time around. If that wasn't the case, as much as I love regular cabs (my last two trucks were RC's), I'd have a hard time buying a regular cab over the double cab this generation. Hell, if you upgrade to an LTZ double cab, you'll be able to get the 6.2 later this year. I just can't imagine spending $38k on a truck that you can't get with the options you want. I do understand the whole garage space issue, now my truck has to sit in the driveway cause it's too damn long. Just something to think about.
I just don't see that happening, the software on the aftermarket head unit would have to work with GM's software. They might be able to get the steering wheel controls to work but that's sometimes difficult.
The space above the base equinox radio is a small storage area. I don't think they have space for that on the truck dash or it would look out of place.
It'll be something to watch in the next few months....I know if I was buying a new truck I'd put a hard roll up Pace Edwards cover on it and change the radio probably right off the bat.
I'll keep checking with my radio guys and see what they say as they get in the parts.....I haven't seen a aftermarket kit *lately* that didn't duplicate how well it integrated with the factory set up.
I'm curious what they figure out. Here's some of the things the DIC does with the radio.
Yeah, I'm familiar with it. My wife's car is a 2013 Nox. I was just using it as an example.
I saw a few of those things when we test drove one last week....That's what's so confusing even though the radio screen is small in size it's still pretty fancy !
Just wish it had the bigger screen to match the bigger functions....I have a 6 inch in mine now and that 4.2inch is quite a bit harder to see.
Who knows maybe for 2015 they'll fix it.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
