First 2014 Regular Cab I've seen at a dealer
If my wife and Ii do the short box reg cab again we are going to swap out the cloth seats and get some Katskins. Since I am not holding out much hope of an upgraded interior for the reg cabs after seeing these pictures!
I don't suspect the GMC's will be any different...........
I am still holding out hope they will announce a truck to compete with the Ram R/T (or Sport) or the Ford Tremor.
They have said they are paying attention to what Ford and Dodge have done with the Harley, Raptor and Longhorn trucks....so maybe after these are out a little while they come out with a sport package or something a long those lines.
Not unreasonable to me.
The folks over at pickuptrucks.com have mentioned hearing rumors of such a truck too.
  • Replies 59
I just hope they come out with it before next summer. That is when the lease on my little truck runs out!
Guess I won't add the sticker, keeps saying the file is too big.
Anyway, $36,090 for the truck above with a 4.3 V6 4WD with the LT Convenience Package.
I know they have to make money on what they sell, but damn.
...& reg cabs never seem to get the rebates that the ext/crews gets.
It's rough. A reg. cab configured how I want it is like $38k- Z71 LT, 5.3, preferred pkg, 18s. ITBC, snow plow prep (to add a factory switch/wiring for aux. lights).
Omg that is plain ridiculous!
I hope so too...we went and drove a regular cab today....and I'm sold....they are much better looking in person than the pictures show !
That is a lot...same as I'm looking at too !
But it's really pretty much in line with their normal price increases.
I bought a 90 Silverado new for $15,500 list price....loaded 2WD....buckets seats and all.
And I bought a 2007 Silverado for $30,000....4WD Z71
Now the 2014 is $38,000.
Just about $1,000 a year seems to be pretty much standard mark up.
Just seems wrong. Sticker on my current truck (2011) was $37,330 and the new regular cab is more! Oh well. I'll buy one, just might be another year or two depending on finances.
I know it.....a regular cab should be (you would hope) less than a crew or double cab....but not really so much nowadays.
Finally got to see a regular cab in person today and took a few real life pictures !
How angular the transition from the hood to front fender is really noticeable in person....much more than the pictures.
Reminds me of the old Chevy trucks....I really like it !
Took this one comparing ours to the new one....but unfortunately you can't tell as much as I'd hoped....some of the new lines don't show as much in pictures !
Plus my truck was a little closer to the camera than the new one....so the size it's very proportional....but if gives you a look anyway :)
Keeping my fingers crossed for the following:
6.2L
leather heated/cooled seats
heated steering wheel
NAV
center console
climate control
6.2L
NAV
center console
climate control
Those are all great ideas to me !
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
