Onstar tracking prevention
Originally Posted by Syvester
There are probably fuses for it. If you don't have navigation and don't intend to keep XM you could unplug the antenna.
Just make sure you also toss that cell phone, stop using credit cards, get off the internet and everything else too. ;)
None of those will stop forward movement in my awesome new Sierra... well awesome with one exceptipn ONSTAR! HAHA
Syvester,
I just wanted to provide a little clarification. Even if your vehicle was previously activated, if the subscription expires or you choose to cancel it, your OnStar system will be deactivated and your two way connection will be disabled. All services will be inactive and OnStar can not connect to the vehicle without a keypress from the mirror to be reestablished. I hope this answers your question.
~Sara, OnStar Advisor
Social Media Team
Syvester,
Social Media Team
But OnStar can still comminicate with you. This has happened to me twice now. I'll be listening to a great song, with the volume turned up. All of sudden, my song will be interupted by some OnStar Ad, informing me I need to renew because I no longer have this or that and the protection of OnStar. If this isn't intrusive, I don't know what is? I did not to renew with OnStar after my 6 month free subscription ran out so stop harassing me with Ad's! It's like an annoying telemarketer you can't hang up from. You just have to sit there and listen to crap you already know. Very annoying and intrusive!
Haider320,
I understand your frustrations. I would be more than happy to ensure your vehicle is flagged to no longer receive these messages from us again in the future. Please send me a PM with the full VIN of your vehicle. Thank you! I hope to hear from you soon.
Social Media Team
I was surprised my 2014 Silverado doesnt have OnStar, apparently 1W/T doesn't include OnStar but 2W/T does include OnStar.
I wish I could stop getting the OnStar messages as well. Last time was listening to the radio, time before that I had a call on the truck via BT with my boss and is disconnected the call and forced me to listen to the message.
Sadly you cant get rid of the OnStar either, it is built into the radio module now on this generation of truck.
exactly my point, you should be able to over ride the message and sometimes the sat rad is on with advertising out of the blue??
I don't believe for a New York second that the OnStar being expired, that you can't be tracked by them anytime they want to. Even after they take you off their "list". As said before, you are being tracked by way more than OnStar everyday.
Haider320,
Social Media Team
Sara - I sent you a PM - thanks for the help.
Haider320,
Social Media Team
so this quote "your OnStar system will be deactivated and your two way connection will be disabled. All services will be inactive and OnStar can not connect to the vehicle without a keypress from the mirror to be reestablished. I hope this answers your question." is basically retracted by this post? Onstar can and will stay connected until the system IS physically dissabled.
I work in the electronic technology world at the manufacturing level, i know how to engineer a system to dissable this POS and will, I only hope I can keep the camera and sound system in tact. I think it's an invasion of privacy when I cannot turn it off and on as I choose.
RD
Imagine when OnStar really gets desparate and sells commercial access to your vehicle's radio from other advertisers. Won't that be a hoot!!???
