It took balls to cut up the bedside just for an exhaust tip.
i cut that hole 2 days after buying her besides the way i see it now i won't hit my pipes on anything since nothing hangs below the frame and i think it looks pretty bad ass
Still a stocker, but I already got her dirrrrrty and tested her towing capabilities at the same time.
The only thing I notice here is green shirt thumb deep in his nose.
Also just noticed the 2500 badge on the driver door....did green shirt dig that out of his nose too?
Edited by Kerrslight
  • Like 9
Any tire rubbing with your setup?
Only rub i have is a full lock. Even then its not bad since its only on the control arm.
Loving my new toy. :thumbs:
Ok. White, Z71, crew and rear sliding window... way to make a guy jealous.. :P
Congrats on the new rig though lol. She's a beauty.
My buddy's 2015 Custom Sport that we took on a hunting trip today
What size leveling kit and bfg's are those? I am having trouble finding bfg's in a 275 or 285 with the raised white letters like that. Any help would be greatly appreciated!
www.gm-trucks.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=51676
Edited by taylorcam11
Hey man its a truxxx 2 inch level, with 285/65/20 but these are KO1 not KO2 they might be discontinued. and they dont make the KO2 with the raised white letter in a 20" just an 18"
Thanks man.....i reckon that explains why i can't find them with raised white letters!
that sucks man, i Love the solid white letter.did you try BFGoodrich Mud Terrain? or Cooper STT Pro?
I believe he was able to get rid of all the debris from this nose haha; as for the 2500, please have a seat, it's gonna take too long to explain.
WT in Mexico is called "Silverado"; if it's the single cab with the V6, it gets the 1500 badge. If it's the single cab with v8 (2wd or 4wd), double cab (only 2wd) or crew cab (2wd or 4wd), it'll get the 2500 badge (although it's not an HD, it's the 1500 at heart.
Any other trim is called "Cheyenne", and that's what you get with the Z71 or High Country versions.
Edited by royrjs
That thing looks slow and I'm sure that supercharger sounds terrible.. You should really post up some burnout videos to prove me otherwise.
  • Like 7
Its a true sleeper...I Supercharged it when it had 1200 miles on her and now have 3000 miles so.. when I get done toasting these tires I plan on adding wheels and fatter meats.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,066 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
