Yes it is. If it was the four door diesel version like they sell in other countries I would so be rocking this thing. Gets pretty good mpg too
I'd definitely love to own one of those! So unique!
My son's 2014!
Sent from my SM-G920V using Tapatalk
LOL... That's kewl... Does it have a Vibration at 7 to 8 inches per second? If it does don't call GM... Bring it to you local Hobbie Shop..
Yup... His and hers..... She got hers first then i got mine.... I did the level and 33s and she was so in love with it that she wanted it for hers.... So as an early birthday present i did hers....
Mama wants a corsa catback next..... What have i done lol
haha... Very cool although I could see how this could get expensive fast too when you have to take the cost of every mod and multiply it by 2. :rollin:
Txjose...the ko2's size? Are they the 275/60r20? Looking good by the way.
Yessirrr... Thats what she has... Also i dnt remember if she got a pro comp or rough country but its a 2" level
Sorry double post dnt know how to multi quote from cell lolz
Haha bo the lift and tires were for her bday.... She is doing the rest her self.... Mama makes good money i'm just the bad influence lol
Nothing wrong with that...the girl has good taste. :thumbs:
Also how does she like the KO2's? They have been the best tires I've ever owned and are wearing well too.
(by the way to quote more than one person in the same post just click "multi-quote" for each one that you want to quote and they should appear down in the "Reply" window. :)
She loves them....she has an itch now to like crawl over curbs and drive on the dunes on the beach lol.... If she gets stuck im a little far away to yank her out lol hers is just a 2wd with a G80
Uh oh....that could be an issue...you're in Texas and she's in North Dakota?
My only issue with them is that they can be stone throwers, but usually only an issue if you're driving down an actual full stone road.
Backwards.... Im in ND and she's in Tx lol..... And she never goes off road so she wont have that problem.... I had to talk her out of toyo mts because of road noise just for the look of MTs lol.... Tho thats what i did but i could care less lol
Those are the RT's aren't they? How do you like them so far? Have you had them long enough to have any experience with how they wear?
I've had mine for several thousand miles and the tires show absolutely no signs of wear. If this continues I'd expect a tread life well over the 45k warranty.
Sent from my SM-G900P using Tapatalk
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
