Traded in my 2010 LS last weekend for this 2015 LT with nav and leather, love the upgrades. So far, I tinted the front windows, installed lowering shackles and drop blocks in the rear to level it out, and plasti dipped the bowties. Soon it'll be de-badged and I'm looking to trade or sell the chrome grille to get a color match one (not really a big fan of chrome). Anyone know what these chrome grilles sell for?
Good looking truck. Really like night shot. Front needs some tint to help match all the black.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Tint is coming on my next day off. Def needs it!
I really like your truck man. I really wish I would of spent the extra cash for a 4x4 now. Lift, wheels, and tires look great and compliment the body lines real well.
Looks great ...... enjoy !
A few weeks back camping in the White Mountains in Arizona. This picture is actually a part of contest I'm currently in as a Chevy finalist. Feel free to check it out and vote :chevrolet:http://www.realtruck.com/truck-madness/
Not sure if I have put up any pictures with the Napier tent.
Edited by AzNikko
  • Like 10
Took me a year or so to decide on what to do with it but here is my 14 SLT. 2.5in RC level in front 2in Block in back. 285 60 R20 Duratracs. Subtle which is what I wanted but very good ride and performance.
Before & After
  • Like 3
Very sharp truck. How about a review of those ICI steps?
275/60r20 BFG KO2, 2" level
Edited by hbshaw
Traded my silver 2014 for a red 2015. Leveled with 285/65/20 bfg ko2.
Any rubbing with this size tire?
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 600 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
