Yeah I was trying to figure it out on my phone but could not lol. They are Toyo R/T 33x12.50x20 and I actually only have 600 miles on them so far but I already know I am going to like them. They humm a little bit on the interstate which is not bad and ride really smooth. They were referred to me by a friend who said they are the best tires he has every run.
Thanks man. Good to hear. I've been contemplating what Toyo tire I want to go with for a while now. I was set on the MT, but I don't really want the noise and I mainly drive highway so I don't know that I NEED them. I really like the AT2, but I don't think they look aggressive enough. Really liking the look of these RT's. Great looking truck!
I'm looking at the 33 inch RT'S also. Looks like the perfect mix between the 2.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Twice I've come out of Home Depot to have another k2 parked next to me.
Sent from my SM-G920V using Tapatalk
Truck guys gotta stick together and I've had this happen to me on a number of occasions too. One time I came out from a store and found 4 other trucks parked around me.
What wheels & tires? Those really set off the whole package to me!
Centerline Stingray III 22x9
Cooper XSTa 305/45/22
bad pics because i was in a rush but this is mine and my girls 14s on levling kits and 33s....hers are BFG Ko2s
his and hers 1
her side
20150513 182901
Edited by Txjose
I always park by other newer vehicles hoping they care as much about the money they spent as I do.
Me and my brothers lowered 3/4 ton toyota dually at Rod Run this past weekend
More like 1/4 ton lol
Don't let it fool you it hauls but its a rare one though as most of the toyota dually are the 1 tons and this one is the 3/4 ton
Not sure how I posted this in the wrong thread earlier. I'm crazy. Anyway, I liked this pic....was taking pics of the mustang earlier after cleaning her up and decided to snap this one.
Sent from my Note 4
That Toyota is amazing!!
Yes it is. If it was the four door diesel version like they sell in other countries I would so be rocking this thing. Gets pretty good mpg too
His and hers pickups? Sounds like a match made in heaven if you ask me...hold on to that girl.
Yup... His and hers..... She got hers first then i got mine.... I did the level and 33s and she was so in love with it that she wanted it for hers.... So as an early birthday present i did hers....
Mama wants a corsa catback next..... What have i done lol
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
