Here is my 2015 SLT All Terrain
Those are the RT's aren't they? How do you like them so far? Have you had them long enough to have any experience with how they wear?
Twice I've come out of Home Depot to have another k2 parked next to me.
Sent from my SM-G920V using Tapatalk
What set up of tires and lift do you have? Looks very good.
2 inch RC level and LT275 70 18 Nitto Terra Grapplers. Thanks
Looks great!! any rubbing issues?
Yes these tire rub the carpet liner pretty easy and at full turn they rub upper control arms. I should have tryed moving the carpet liner but never did. I just traded the truck for a red 2015 just like it. I am going to put the same 2.5 level kit and go with 285/65/20 big ko2 this time. The Chevy dealer I bought my truck from levels a lot of trucks and that the tire they use. They do zip tie the carpet liner back though.
It looks like you tried to respond, but didnt lol
Those front wheels are BEGGING for some Willwoods!
You buying? Unfortunately that will never happen. I'm building another car right now and all the cool parts are going on it.
Yeah I was trying to figure it out on my phone but could not lol. They are Toyo R/T 33x12.50x20 and I actually only have 600 miles on them so far but I already know I am going to like them. They humm a little bit on the interstate which is not bad and ride really smooth. They were referred to me by a friend who said they are the best tires he has every run.
I don't blame you. Its a good looking setup you have there though.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
