Looks great man! Probably my favorite pic of ur truck I've seen
Sent from my iPhone 6+
thanks bro i appreciate it, my fav of yours is the first pic you posted of it, when you first got it, sweet ride for sure, wished you lived closer so we can have them sun bath next to each other, now that'll be a badass pic
New to the site and thought I would post up my new ride.
2014 SLT Z71 with nearly every available option.
Traded this in
Got this
Great trade! I traded in my 02 Yukon same body style for the same truck!
Thanks man. That would be an awesome photo shoot for sure!!
Yes it would , I have a friend that lives pretty close to me, he has a high country, he has a 8" lift with the same wheels as me, I'll try and get a pic of both of them together
Edited by Clint D
I know this isn't dirty to some of you guys, but pretty dirty for me. Love this blue with some crap stuck on it!
Sent from Tapatalk App - Samsung S6
Just went to the local off road shop. Got a 2" front Zone leveling kit, 20x9 fuel maverick wheels on there way, 275-60-20 bfg KO2s, bedtred bed liner by bedrug, mud flaps, rain guards, floor mats. Going to get the front tinted soon. Thinking about getting some n-fab nerf bars.
Edited by ChevyLife207
Traded this in
Got this
I'd like to see what else is in that hangar! Nice pickup!
Just my truck up a couple weeks ago. So far I've just removed some emblems and had it tinted. Leveling kit (lowering the rear) should be in next week.
Playing around with the camera during some spare time at work today. Thought this one came out pretty cool.
Sent from my iPhone 6 using Tapatalk
Edited by tibnyi01
I added a cab-high topper to my truck. Some will think it's sacrilege, but it will work well for me.
Edited by nfisherman
I think these trucks look great with a topper. If I had more use for one I'd get it
Looks great man[emoji106][emoji106]
Edited by Mike1220
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
