It took balls to cut up the bedside just for an exhaust tip.
i cut that hole 2 days after buying her besides the way i see it now i won't hit my pipes on anything since nothing hangs below the frame and i think it looks pretty bad ass
  • Like 3
Still a stocker, but I already got her dirrrrrty and tested her towing capabilities at the same time.
The only thing I notice here is green shirt thumb deep in his nose.
Also just noticed the 2500 badge on the driver door....did green shirt dig that out of his nose too?
Edited by Kerrslight
  • Like 9
Any tire rubbing with your setup?
Only rub i have is a full lock. Even then its not bad since its only on the control arm.
Loving my new toy. :thumbs:
Ok. White, Z71, crew and rear sliding window... way to make a guy jealous.. :P
Congrats on the new rig though lol. She's a beauty.
My buddy's 2015 Custom Sport that we took on a hunting trip today
What size leveling kit and bfg's are those? I am having trouble finding bfg's in a 275 or 285 with the raised white letters like that. Any help would be greatly appreciated!
www.gm-trucks.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=51676
Edited by taylorcam11
Hey man its a truxxx 2 inch level, with 285/65/20 but these are KO1 not KO2 they might be discontinued. and they dont make the KO2 with the raised white letter in a 20" just an 18"
Thanks man.....i reckon that explains why i can't find them with raised white letters!
that sucks man, i Love the solid white letter.did you try BFGoodrich Mud Terrain? or Cooper STT Pro?
I believe he was able to get rid of all the debris from this nose haha; as for the 2500, please have a seat, it's gonna take too long to explain.
WT in Mexico is called "Silverado"; if it's the single cab with the V6, it gets the 1500 badge. If it's the single cab with v8 (2wd or 4wd), double cab (only 2wd) or crew cab (2wd or 4wd), it'll get the 2500 badge (although it's not an HD, it's the 1500 at heart.
Any other trim is called "Cheyenne", and that's what you get with the Z71 or High Country versions.
Edited by royrjs
That thing looks slow and I'm sure that supercharger sounds terrible.. You should really post up some burnout videos to prove me otherwise.
  • Like 7
Its a true sleeper...I Supercharged it when it had 1200 miles on her and now have 3000 miles so.. when I get done toasting these tires I plan on adding wheels and fatter meats.
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 528 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
