Here's my 2016 Sierra SLT Z71, had it just over a month and have done the rough country level kit and tint so far.
Future plans include: intake/exhaust/tune, color matching the chrome, along with some wheels and tires.
(Will provide better pictures soon)
Edited by ANazir
and tires.
Edited by Bigfoot16
D0393A9B-9F41-4598-A739-80EC4C04C9ED_zps
no snow in Florida :ninja:
Dang! Good looking truck! That is sweet! what size lift? and what is the wheel/ tire size combo? looks great!
Edited by tyrich88
Dang! Good looking truck! That is sweet! You running a lift and what is the wheel/ tire size combo?
thank you guys.
to answer:
5" Rough Country lift
645f97a9b14a552145431fa9abb9cde6_zpsgd2h
20x9" (+20) Fuel Assault with Nitto G2 305/55/20, flush on the flares (rear 2" hubcentric spacers only)
i had 20x10 (-18) but was too aggressive and rubbed like crazy.
85138C17-8C66-47E5-9E17-035716BB6501_zps
i am short :tear: so, Amp Research Power Step XL
59A17F1D-6D67-413D-9BE1-46E4FC785AA0_zps
6BD76DC7-B5D3-46F6-A511-CCB7BF02C726_zps
very happy with the results so far
thank you guys.
to answer:
Sal, there are 2 5 inch lifts available ..one with new steering knuckles or spindles and one with UCA drop brackets. Curious on which one you got? Also did you use their rear shocks...if so which ones? Happy with the shocks? Did u install or someone else? Sorry for all the questions. That's the exact height I want. Just right!!
Sent from my Nexus 6P using Tapatalk
got the one with the knuckles
http://www.roughcountry.com/gm-suspension-lift-kit-247-8.html
i did use their rear shocks (for now) 2.2 option (not crazy about them, but OK). had had someone else install (shop) for $300 (i guess because it was part of a package including wheels, tires, flares, etc.)
So far, i have been giving them a run for the money.
i live on a farm (no asphalt) and work for a large farming company (always on the field), so i do take advantage of the extra clearance and traction every day. i have 3.08 gears so that's next
Didn't go higher because, like i said, i am short (5'.5") and not looking forward to ungraceful dismounts in front of my crew :ninja:
Oh didn't know you were 2wd. Still I like the height. Just enough. A little more work for the 4wd but hey. Need mine to get on your appearance level. Very nice
Love these trucks in the snow!
Edited by slevitt3335
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
