3dceb3d01a186db810b5335b69f9320e.jpggot a new chrome 48 inch sticker
RTR!!!!!
0 offset, any rubbing with this offset, on road/ off road?
Yes I had some rubbing on the carpet liner so I chopped it away. Full turn might get a bit of a rub and more so off-road when on uneven ground but nothing major
I actually ordered a set of Nitto Exo Grappler 305/55/20 yesterday so hoping they fit ok, seen mixed reviews on here. My issue now is with the height of the 275/65/20 causing the rub so hoping the slightly shorter 305/55/20 work out
Here is my 2016 Iridium Denali, 6.2L, 2wheel drive truck completed (for now) with all the updates.
Chrome handles and mirror caps replaced and painted Iridium, chrome window trim replaced with black, new Bakflip VP Tonneau, chrome door trim replaced with black, chrome Denali emblems (3) replaced with black (Ewing dealership did a great job), 6.2L tailgate badge (where Sierra was) from Emblempros, black GMC grill and tailgate emblems from American Brothers Design, black lug nuts and wheel locks by McGard (84640), GMC OEM Black gloss 22" wheels, Michelin Premier LTX 285/45 22 tires, black center caps from a local wheel shop, Black Bear Tune, GM Boral Exhaust Cat Back System, AirAid Intake (just tube), and Amp Research Power Steps.
Before
After
Looks great, nice job. I've been looking for a 6.2 emblem as well, I like the one you have and where you placed it too
A little pic update. Not a big fan of chrome and I like black better. : )
Before:
87b07619-e3ae-4357-8932-a4f3332bce84_zps
After:
d9da2e39-40e3-45aa-990c-2028d8961738_zps
Awesome job!
Enjoying the beautiful weather. Still got some chrome to remove...
  • Like 10
Looks awesome!
Wow! Nice ride!!
Sent From My Galaxy S6 Edge+
So I just added a 2.5 Rough country level w/ blocks on some 285/75/18 Toyo ATs on my stock wheels.
I have the same truck, rims and level kit. I was looking at that size tire but I'm worried about the rubbing. Do you have any rubbing? What about at full lock while "flexing", jumping a curb, off-roading, etc? Truck looks great.
Factory 22" wheels with Terra Grappler G2. Tinted and leveling kit.
Gayest stickers on the planet lol. What's the point?
I'm lost. What stickers?
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
