1 hour ago, Skidsareforkids said:
Love the wheels! I’m thinking of getting those too. How do you like them? What size of tires are those?
I went with these cuz I was tired of the chrome CK375s I had on! I love the way it looks. I just need to black out the honeycomb on the grill. I ended up getting Michelin Defenders 285/45/22 from Discount. Dealership recommended I balance them with 20lbs or less. No issues whatsoever and rides smooth.
8 hours ago, tyler.frost92 said:
what mudflaps are those?
They're made by Bulletproof Bumpers.. but the shop i deal with has them custom made with their logo on it, Farleys Truck & Auto Addictions.
CNC cut stainless steel kickback to clear larger tires, heavy duty rubber with all stainless hardware. These are the 12" wide, black powdercoat... but you can get them in plenty of different sizes.
On 2/8/2018 at 10:23 PM, Josh154 said:
285 does in fact determine height as well. Go look at 285/55, 295/55 and 305/55. Both the 295 and 305 is taller than the 285. The 305/55 comes in nearly a inch taller than 285/55.
The dimensions of a 285/65r18 tire are 11.22” wide (section width) & 32.6” tall (outside dia)
The section width is 285mm wide  (There are 25.4mm to an inch)
STEP 1) 285mm divided by 25.4” = 11.22” (section width)
STEP 2) Multiply 11.22 (section width) by .65 (aspect ratio)
11.22 x .65 = 7.29” (section height)
To find the outside diameter
Multiply 7.29 (section height) x 2 then add rim diameter
STEP 3) 7.29” x 2 =  14.58” + 18.0” = 32.58” round out to 32.6  (outside dia)
New to the forum. Here is my truck:
 2014 1500 LT "custom"
Bilstein 5100's, front on highest setting, Rough Country rear block. (removed the front spacer when adding the Bilsteins)
Fuel Titan 20x10
Nitto Ridge Grappler 33x12.50
Fuel Titan 20x10
You shouldn't be squatting with the RC block in the rear and 5100's up front. If anything the front should still be lower.
Fuel Titan 20x10
Any rubbing up front with 20x10 and 33x12.5?
5ea98284134d67d0d926b0a54cff6146.jpg0d3224a925b9f608ab4e10d61c032537.jpg 2014 Silverado 6" BDS with 35x12.5 Cooper st maxx tires and 18x9 fuel octane wheels.
I agree. I believe they left the top spacer on top of the shocks and only pulled out the bottom spacer part of the RC level kit. I had the shocks put on at the same times as the wheels. There is a little squat, this picture makes it look like there is more than it does in person.
The shop I had put the shocks and wheels on did some trimming, not sure exactly what, but even with the trimming it only rubs in reverse at almost full lock on the left. Weird, not the right but only left. And its very little. Once I get past a certain angle and get to full lock theres no rub.
Has any of you went from a Zone 4.5” lift to the 6.5”? Tossing the idea around... PFA
Fuel Titan 20x10
Is that chrome on the mirror stick on?
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
It’s just blocks and strut spacers, very easy. I did it on my ‘13
4.5" Zone
16 Silverado CCSB
-Zone 4.5" Suspension Lift
-Hostile Sprocket 20x12 -44
-AMP Attack M/T 285/55
    Randy Ginoza
    Randy Ginoza
  • Who's Online   3 Members, 0 Anonymous, 2,122 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
