1 hour ago, Skidsareforkids said:
Love the wheels! I’m thinking of getting those too. How do you like them? What size of tires are those?
I went with these cuz I was tired of the chrome CK375s I had on! I love the way it looks. I just need to black out the honeycomb on the grill. I ended up getting Michelin Defenders 285/45/22 from Discount. Dealership recommended I balance them with 20lbs or less. No issues whatsoever and rides smooth.
8 hours ago, tyler.frost92 said:
what mudflaps are those?
They're made by Bulletproof Bumpers.. but the shop i deal with has them custom made with their logo on it, Farleys Truck & Auto Addictions.
CNC cut stainless steel kickback to clear larger tires, heavy duty rubber with all stainless hardware. These are the 12" wide, black powdercoat... but you can get them in plenty of different sizes.
On 2/8/2018 at 10:23 PM, Josh154 said:
285 does in fact determine height as well. Go look at 285/55, 295/55 and 305/55. Both the 295 and 305 is taller than the 285. The 305/55 comes in nearly a inch taller than 285/55.
The dimensions of a 285/65r18 tire are 11.22” wide (section width) & 32.6” tall (outside dia)
The section width is 285mm wide  (There are 25.4mm to an inch)
STEP 1) 285mm divided by 25.4” = 11.22” (section width)
STEP 2) Multiply 11.22 (section width) by .65 (aspect ratio)
11.22 x .65 = 7.29” (section height)
To find the outside diameter
Multiply 7.29 (section height) x 2 then add rim diameter
STEP 3) 7.29” x 2 =  14.58” + 18.0” = 32.58” round out to 32.6  (outside dia)
New to the forum. Here is my truck:
 2014 1500 LT "custom"
Bilstein 5100's, front on highest setting, Rough Country rear block. (removed the front spacer when adding the Bilsteins)
Fuel Titan 20x10
Nitto Ridge Grappler 33x12.50
Fuel Titan 20x10
You shouldn't be squatting with the RC block in the rear and 5100's up front. If anything the front should still be lower.
Fuel Titan 20x10
Any rubbing up front with 20x10 and 33x12.5?
5ea98284134d67d0d926b0a54cff6146.jpg0d3224a925b9f608ab4e10d61c032537.jpg 2014 Silverado 6" BDS with 35x12.5 Cooper st maxx tires and 18x9 fuel octane wheels.
I agree. I believe they left the top spacer on top of the shocks and only pulled out the bottom spacer part of the RC level kit. I had the shocks put on at the same times as the wheels. There is a little squat, this picture makes it look like there is more than it does in person.
The shop I had put the shocks and wheels on did some trimming, not sure exactly what, but even with the trimming it only rubs in reverse at almost full lock on the left. Weird, not the right but only left. And its very little. Once I get past a certain angle and get to full lock theres no rub.
Has any of you went from a Zone 4.5” lift to the 6.5”? Tossing the idea around... PFA
Fuel Titan 20x10
Is that chrome on the mirror stick on?
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
It’s just blocks and strut spacers, very easy. I did it on my ‘13
4.5" Zone
16 Silverado CCSB
-Zone 4.5" Suspension Lift
-Hostile Sprocket 20x12 -44
-AMP Attack M/T 285/55
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
