I'm looking to get a 4 inch suspension lift for my 2014 silverado. Can I see some pics so I can get an idea what it will look like.
Also I'll be getting 20x10 fuel Mavericks with 33 inch trail grapplers
Almost exactly what you are looking for, 2.5" level 1.5" body 20x10 and 33s
I just put on the "winter wheels". 22" chromies go back on in April.
These are my favorite rims on these trucks anyways. I bought a z71 with 18's my second go round'. My first had these and had terrible vibration issues. Edited by 20Bowtie14
You might save money but 4x4 are more useful and here in AZ the market is flooded with 2wd. 4x4 ups the value and I have never had an issue with 4x4. Now awd, that's another story, my wife's denali was a nightmare.
I really like your truck man. I really wish I would of spent the extra cash for a 4x4 now. Lift, wheels, and tires look great and compliment the body lines real well.
Thanks man.
Decided to plasti-dip my wheels. I'm happy with them. Cheap way to get a different look. Sorry about the dirty truck.
Edited by Yamiryder
  • Like 4
4wd cost is more than recouped on resale here as well.
attachicon.gifTruck 1214-1.jpgattachicon.gifTruck 1214-3.jpgattachicon.gifTruck 1214-4.jpg
Where'd you get your taillights anzo?
The Taillights are Eagle Eyes. I have had a set from the same company on my corvette for several years without any problems at all.
The lights look good and easy installation.
http://www.ebay.com/sch/sis.html?_kw=PAIR+%22L.E.D.%22+LED+TAIL+LIGHTS+SMOKE+PLUG+N+PLAY+FOR+2014-2015+GMC+SIERRA+1500&_id=301219134579
From the other night when I installed my VLEDs! There was a heavy mist/fog that made for some pretty cool picture opportunities!
I was thinking bout doing that set up as well with the light bars. How does it look with both light bars? Is it worth it ? Did u make a bracket for behind the grill ? And how did you rig it up in ur truck ?
4F4F8A75-6BF9-4507-9F8A-BF500CD47F12_zps
B054DC8E-DD7A-468E-B52C-887677FC4C07_zps
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
