^^^ i think i said the same thing my first week... GL with that. Nice truck
Pretty sure that 's just a wrap
Might be plastidip as well
Either option would be cheaper, but maybe he's a painter!
Either way, the truck looks great! :cheers:
Edited by Luster
New to the Club!...First truck in 20 years, man things have changed..........
[post=KGvBSr2.jpg]My 2014 GMC Sierra SLE Terrain[/post]
Either option would be MUCH less expensive than paint. Not to mention they are both reversible. I'll bet it's at least 5K to have a truck painted... unless he's a painter! :cheers:
I bet he works at a graphic decal place or something similar. Matte paint on a vehicle as big as a truck would be wayy up there in $$$$. And I've seen some plasti-dip cars but the finish is never as good as a wrap. Looking at the sheen on the guys truck and the quality of the finish I'd bet is a wrap. My guess is that if it would of been painted the bumpers would of been taken care of the same time. Would of been odd to spend all that time, prep work and money to just paint pumpers some other time.
He distinctly said "painted" and later that the chrome (I assume he's talking about the bumpers as well) would be taken care of soon enough.
What incentive would he have to lie about it being paint?
  • Like 6
And for the better!
I sense a lot of jealousy towards @Maineman truck. Let him be, regardless of what he did the truck looks nice.
  • Like 7
Yes really, I was asking if he actually spent the money and had it properly painted or if he cheaper out and pull on a coat of peel off paint… Plastidip is not a proper paint job, it's an I can't commit to my decision paint job…
If he actually painted it and committed, then I'm impressed. But, if it's plastidip, then it's just another 'meh' truck…
Edited by Daly
Here is my new toy.
Body colored the wheel moldings and front fascia by the tow hooks.
How and better pics!
I like it! Any plans for wheels?
Yeah some black 18in smitty built rims, and 33in nitto terra grapplers Edited by maineman
Or I'm aware that I could just order black bumpers and swap em out, money for the paint can be saved, with patience anything is attainable.
    • Monday looks like a good day for the dealer to test an ac issue. Hopefully it all turns out good.
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
