Yeah, I have to agree with Wendy on this one - I've worked in a high end decal/wrap/tint shop for over 6 years. That unit is definitely dipped or wrapped - My money is on wrap. I can spot a wrap a mile away.
Sometimes two miles on a clear day.
I have no reason to doubt the owner in fact what difference does it make. I on the other hand don't have the balls to paint how much would it run to wrap?
We usually don't do jobs that large - our usual customers are sports cars, high end exotics or rally/track only cars. That being said, we have done several trucks.
It really depends on how detailed you want the job done. If you only want externally visible panels - Around $4,500. If you want to go all out for door jambs and such, closer to $6,000. Just takes a lot more time, and a lot of the pieces have to be cut by hand.
With quality material, a wrap like that could easily stand up to a few winters of abuse, before showing signs of wear.
I am actually in the market for a wrap. I wasn't convinced they keep the paint good but I was at a wrap shop while they pulled a 4 year old wrap off and the paint looked great! I want something different and not the normal flat black.
Well that's expensive for a wrap, and I doubt it will ever be as clean as a real paint job. I know a lot of people that do professional auto painting and for me they'll do my truck for no more then 3gs.
attachicon.giftruck01.jpg Got the wheel moldings color matched
Looks great. I hate the plastic mouldings. How did you have it done? How much? Edited by ahahnu
You can buy the color keyed wheel mouldings from GM.
Edited by mafd2
Last I looked they only sold certain colors. Just checked again and only black, white, red, and prime. Stealth Gray isn't on the list, hence how did he do it?
Sonoma red, white diamond, summit white, Onyx Black, quicksilver and Prime-paint to match.
Paint to match is $200 cheaper than the colored. ones.
It's cheaper to paint the ones you already have on the truck. The dealership where I bought it painted the 4 moldings and the front fascia around the towhooks for $210.00
Brought it to them in the morning and picked them up installed on the truck the next morning. without my truck 1 day.
Just traded my 2014 High Country for this 2015 LTZ last night. It's the University of Texas Edition, but I pulled the stupid looking stickers off. I actually like the way this one drives compared to the High Country. a27f77457a44cded5c9ba8394b94069c.jpg
I'm not being hateful, truck looks great, I just really don't think its painted. You should snap some pictures of the door jambs though.
  • Like 10
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
