Thanks! I really love the tune Lew made. Its shifts better, more responsive, all around better performance. From observations at this point I'm getting a couple more miles to the gallon too. I really love this truck.
can you give more info on the tune by lew ???? Thanks
I actually learned everything I know here on the forum and on Lew's website, http://diablewtune.com. Initially I purchased a Diablo inTune with no intention of using his service but after reading others satisfaction with his work and knowing I would probably never tune it as well as he I contacted him. I went with the 91/93 tune and the truck runs great, much better than stock. Mind you I don't race the truck, I just wanted the best performance I could get for a reasonable price and I got it. Search the forum and check out his website and decide for yourself.
2016 Silverado 1500, 5.3
Purchased Nov 11, 16
CK156 Chrome Wheels
Michelin Defenders M/S 275x55/20
Borla Touring Exhaust
DiabLew Tune (love it)
EliteEngineering CC
Airaid Intake
eye candy and incidental add-ons
Great looking truck
Where did you get CK156s? They are So hard to find
Thank You for the info
Wow, what a big topic! So, my first post here after picking up a new 2016 Silverado 5.3L LS Double cab with the great 2016 year end 20% off MSRP deals. First attempt to post pics from Photobucket. No flamers! lol
This forum has been invaluable! Thanks for all the input on mods to my new 2016 Silveradu LS Double Cab. Pretty much everythnig I've done, I got here!
After 2-3 weeks of exhaustive research and borderline analysis paralysis on wheels, width, diameter and offset and tire brand and size, after several here had posted here that they had no problems with 305/55r20 and 2" level, I bit the bullet and went with the following setup: Bilstein 5100 adjustable set to max height (1.85" level), Moto Metal 970 20x9 (offset 18), Nitto Terra Grappler G2 305/55r20. Only place where tire came close to fender liner was the inside rear on both front tires. This area of wheel liner can be pulled back about 3/4"and clipped or tied back. I used to body clip/retainers to clip the carpet liner back to metal. No rub whatsoever, minimum 1" clearance.
I performed the Bilstein 5100 install. Removing the factory shock/spring assembly was cake. After renting Autozone spring compressor, I decided not to take a chance on life and limb and went to local NTB a mile away and had them swap new shocks into spring assembly. The have a monster press built for the job and took about 2-3 minutes per assembly. Now, getting the new assembly back in the an added 1.85" of height into place was another story. In short, I recommend a friend and a six pack OR I was able to make it happen with a large crow bar to get more room from lower A-arm to get assembly in place.
Trick was to put the outside (of the 3) top nut on and pull it almost tight to get assembly pulled up as far as possible, then use pry bar between bottom of shock and lower A-arm to get that 1/4-3/8 inch room required to get bottom of shock into place. Other trick is to put bottom shock mount into vise and turn to get stock angle on the mount so that the bottom mount lines up with mount angle on A-arm.
Just put 40lbs in tires. Ride is great. Between improved sound deadening in these new gen trucks and the Nitto Grappler G2 tread pattern, there is virtually no road noise and the ride is fantastic with combo of Bilstein and the Grapplers. I have the Bilstein 5100 rear shocks to match, just waiting until a warmer day or spring.
Did a few other things: Black billet front grill bow tie, removed billboard Chevy emblem on tailgate, may think about de-badging Silverado side emblems later, installed the 4" Dee Zee black oval nerf side steps. Husky Gearbox storage box under rear seat and Husky X-Act Contour front mats (factory rear for now). Color matched door guard molding from eBay (perfect match). Dee Zee bed mat, GM factory tailgate protector. Airaid Jr to let it breater. DiabloSport i2030 tuner to correct tire size and disable DoD/AFM. Trying to decide between muffler delete and replacing factory muffler with the Borla 40943 XR-1 SS 12" muffler. Both seem to sound great.
Mines an LS and didn't come standard with Home Link garage door opener in roof panel, so I ordered and installed 4 parts guys here have provided on Youtube. Install was a breeze and opener sync'd with factory Chamberlain opener immediately. That will probably do it until I find something else you guys come up with that I can't live without.
Oh yeah, after more exhaustive ;^) research on this and other forums on bed covers, I decided to try low end of the spectrum, and ordered the Access Vanish soft cover. Over $2K for an automated retracting bed cover???? Really??? Even the $800-1000 covers seem to have their flaws and detractors. Found a great deal on the Access Vanish on eBay from Thoroughbred Trucks for $270 shipped. I figure if I do;pt like after a few months, I can sell here in Dallas area on craigslist and try again. Seems to have generally good reviews, what I need (easy full bed access and prices is very little risk.
BTW, just sold 2000 Silverado Extended Cab 5.3L LS that I owned for 16 years yesterday. Same truck (well, same level) 16 years earlier (5.3L with with 85 less HP). Best vehicle I ever owned! Decided to do it again! This 2016 has exceeded my expectations so far. I work from home and alternate between a car queen 2003 BMW 530i Sport with about 55k miles on it. I expect to put about 6K a year on this new beast. Need a carport! More $$$$
Fingers Crossed!
Awesome setup, pretty much exactly where I've been debating on going with mine level/tire size wise. Just to clarify on your wheel offset, that's +18, correct? It didn't appear deep enough in the photos to be -18, but I just wanted to verify. Mine are 20x9 +15.
Yes Big Red (BTW, have some great family in OK!), that is correct on wheel offset: MotoMetal 970 20x9 +18. All I can say is that this setup has absolutely NO rubbing after a little over 1000 miles. I know there is very marginal differences between diameter and width of 2 brands of the same tire size, but I can't imagine there would be significant difference between +15 and +18, that's 3mm or .12". I'm very impressed with the ride and look of the Nitto's. They have a lot of great reviews + a 65K mileage wear warranty. Not a single regret!
This is my 2016 Silverado Z 71 Crew Cab, I haven't done a lot, just tinted windows very dark, added weather tech splash guards, cut out the muffler and flapper, I left the factory resonator and added a bigger black exhaust tip. Sounds just like a Magna Flow with out the expense, LOL. Aso have a spray in liner from ArmourThane, Replace crappy factory tiny tires with a couple sizes bigger and meatier Coopers
Edited by Pete Frame Jr.
a010e788eb42d63293b0bea78f26b0f0.jpg ready to get new tires and rims will be going with 37x13.50 with 24s Chevy replicas around February
Sent from my SM-G930W8 using Tapatalk
Is that a ham radio antenna I see on the left fender? What's your setup?
This is my 2016 Silverado Z 71 Crew Cab, I haven't done a lot, just tinted windows very dark, added weather tech splash guards, cut out the muffler and flapper, I left the factory resonator and added a bigger black exhaust tip. Sounds just like a Magna Flow with out the expense, LOL. Aso have a spray in liner from ArmourThane, Replace crappy factory tiny tires with a couple sizes bigger and meatier Coopersattachicon.gifZ71.jpg
welcome - looks good
Photo's of your setup. Thanks
Used and abused last weekend. Best time I have ever had wheeling.
Aftermath.
  • Like 4
    • I had an issue with a new Z-28 some years ago. The 4WDB's were less than adequate when purchased IMO.  I had taken it in for small warranty services and asked them on three occasions to check them. Each time is was "could not duplicate on the service ticket. The warranty ran out about a month after my last visit and had to take it back for warranty rework. I again complained about the brakes. Well, low and behold, this time they determined the rear calipers were sticking and gave me a quote to repair. They had records as well as O had receipts of each time complained about the brakes while still under warranty. My dad was a life long body shop owner and told me to keep my cool and tell them that I wanted to speak to the GM Regional District Manager. The service manager disappeared for a few minutes, came back and told me they would replace the calipers free of charge.
    • Towing a 2022 Lance 24 ft travel trailer with our 2021 GMC Sierra 2500HD, gas.  Loaded, trailer is about 6,000 lb.  We get up to 10 mpg at 55 mpg, such as I-5.  Pleased with the combination.
    • I decided to give it a shot and see what sort of a gong show it would be to a pan drop themed oil change on my 2025 gas truck with the 10 speed. All indications I had seen so far was that there was no way that pan was coming out of there due to the cross over exhaust pipe not allowing enough clearance for the back end of the pan to duck out from under the valve body since it hangs lower than the pan to trans mount flange and certainly the filter does. I never touched any of the exhaust mount hardware at all, be that the engine manifolds to Y pipe, the bracket on the side of the transmission, or the two bolt flange further back behind the trans/transfer case. I put the truck up on four jack stands as there was no way I was going to struggle with that lack of clearance under the truck. The truck was cold as it had sat over night so all the trans fluid had drained to the pan, so I drained the bit of oil that would come out of the level check plug at the bottom near the front of the pan and put the plug back in to reduce the ensuing mess after that. Then took out all but one bolt front and rear and then pushed up on the pan and took out the remaining two bolts and then let the front of the pan tilt and spill out most of its contents into a drain pan. I then popped the pan gasket off its two locating nubs and kicked it a bit to the left side so it was no longer on the flange of the pan to get all the clearance I could and managed to get the pan slipped out of there by swinging the front of the pan to the right but keeping the rear part of the pan inline if not slightly to the left of its mounting flange area and lifting the front of the pan enough to keep the rear part of the pan low enough that allowed the pan to "JUST" slip out without forcing anything. I installed a new trans filter and seal and as per GM instructions on this site I torqued the two bolts to that 44 inch pound goal ( they take an 8 mm socket ) In reversing the pan procedure after I had cleaned up the pan both inside and out completely ( touching the outside of a dirty pan and dealing with installing a gasket at the same time would be a disaster ). First I slipped the pan into place and yes it took me a while as it won't go unless its slid in just at the right angles, then once the back of the pan was into the area of the flange mount, I went and got the gasket and then threaded that through the front of the pan and feeding it under the filter etc and finally working it onto the flange of the pan and lining up the two locating nubs to drop into the pan. Then lifted the pan up into place and get a couple of bolts started and check and make sure the gasket is where its supposed to be as the bolts were being put in. I never used any power tools as I don't have any of the whimsy little drive guns, I use what looks like a small screw driver handle with shank that has a 1/4 drive on the end of it and added an extension and those bolts use a 10 mm socket as some times power tools can bite a person if used on delicate parts ( torqued to 80 inch pounds ). Also should note as per rules around pulling the add plug out first, yes I cracked that loose with a 8 mm Allen bit socket on a 3/8 slim head ratchet as there isn't a lot of room to work with there either due to the exhaust on the right side of the trans.    I already had delco ULV oil on hand and of course the quart bottle pump wasn't made for those small cap threads so I had to use some other containers that the pump would fit and keep transferring oil over into them so a wasted exercise there but indeed the small pump did work just fine as ULV oil is thin and easy to pump in summer time weather. I put in 9.5 quarts as per prior minimum recommendation and yes that cut it pretty close as once I had the truck ( off the jack stands so its level ) and the trans oil up to 167f , about 6 ounces came out but a level kit or what have you could throw it off just enough that it wouldn't be enough oil so probably that 10 quarts is a good amount to put in so one doesn't have to add more oil as when its hot I sure wouldn't want to be adding oil so would have to let the exhaust cool. All I do for warming up the transmission is sit there with it in park and rev it to about 2500 rpm and it takes close to 20 minutes to get it up to that lower limit of 167f, weird how it will warm up more doing that then by driving it, I am not real keen on power braking the truck to get the temp up there and don't seem to have to either. By the way I only have 9000 miles on the truck so probably not a very good payback on doing it that soon and the magnets had such a minor thin layer of fines on them so that was good to see and the color of the oil was a darker red then new oil but still looked very good as it should and I've not done any towing with it so its been living a pretty easy life so far. The filter is made in such a way that its next to impossible to pull out the filter media but there certainly was some fines showing up there which makes sense give the trans having to break in.    I hadn't really planned on explaining this much of what I had done since there are various instruction videos kicking around or I think so, as the gist of my message as that by fluke or what have you, for some reason my truck has just enough clearance to slip the pan out from the trans. Of course there is no guarantee that other trucks like this in general will also allow the pan to be taken out without messing with the exhaust as I expect its probably a crap shoot if it will or won't, I was just happy to find out that mine would work and avoid all the other struggling and possibly damaging things in the process,
    • Do you fellas think Fog Lamps would  be a good upgrade for our 2024 2500 HD Custom ? As you probably know it did not come with them ,  Would you put in GM Chevy parts ? Do they get wired up to the switch panel ( Upfitter or whatever the correct terminology is ) on the dash ? Thanks
