2in rough country level
20x10 xd riots -24 offset
285/55/20 Falken Wildpeak at3wd0ae4ac596a170d440ffedb35619f7da.jpg
Sent from my SM-G920T1 using Tapatalk
- 24 offset?? Are you sure? So you have a pic of the truck down the side?
I have the same tires, how are you liking yours?
Sent from my E6810 using Tapatalk
They don't look that far out there. But unless he's severely confused about which wheels he bought, that's gotta be right. The XD Riot only comes in -24 in the 20x10 model. Gotta go down to the 20x9 to get +18 offset.
That's what I was thinking. I'm shopping for wheels and the shops around here are telling me the most I want to poke the wheels out are a 0 offset.
Maybe being a 20 x 10 has something to do with it...
Haven't had the long, but so far I'm liking them. Yes I'm positive they are -24e0c8a7885352b71ec701b55e06e06a55.jpg
All clean....
man, i really like that look...did you put the fender flares on yourself? i am curious ball park what they ran? i have been thinking about adding them myself...
Now I can see the offset.. Looks good!
Thanks, and yes I installed the flares. I was able to get them from a local shop paint to match for 750. Some days I like them others I don't...
tough to keep clean? what are the cons? they look great! i thought about putting line x or rhino lining them (i have a black truck) but that voids the warranty...(weird i think)...but i never had a chance to look into how much the paint to match would run...
I found some one eBay for a good price, they probably aren't the same as his. If you have 16-17 it cost way more for reasons I don't know or understand. 09b9da83ad57b71915d1e8592b46e621.png
thanks...and well damn...i have a 16...i have done some mild shopping around...but the painted part was really my question...i should have asked it better...
I would say color matched spray paint. If you zoom in it's very slightly not the same gloss to it.
The reason I guess this is because I did my grills trim a color match, even after the gloss you can tell it's a little off when you look.
I could be wrong, but just a guess.
You really can't tell it's a bit off there unless someone points it out. I think it would be different on a fender flare though. No black trim to separate the off-colors and a wider surface are on the flare than the grill.
Thanks but it's a little off, I had to mix colors to make it match as close as I could, gm matalic blue, and Gm aqua blue to get a close color, I bet it be a better color if I did it with a spray gun rather then a rattle can. Lol
There's always that one guy who has to park next to you and makes you want bigger tires. 33s vs 37s
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
