-Low2014- SLT ( New Pics)
-Low2014-
Did the factory 20's / tires rub at all in the font after you dropped it? What about the rear? Did you have to do any trimming on the crossmembers or anyting?
My tires rubbed fender wells in the front and my driveshaft and differential would bump a crossmember and the bottom of the bed, respectively, on My 2006 CC sittin on a DJM 4/6. Definitely don't want these issue on my 14.
What's up JRoss
The factory 20's didn't rub at all except doing 20 mph U-turns which I don't do very often LOL and the 24's don't either. There was no cutting, trimming or anything done to the frame. You do have to cut the bump stop supports off and re-install the bump stops on the frame. I don't have ANY issues with the back.
I have a 05 ECSB with a DJM 2-4" drop and I didn't have a C-notch done and I would also hit the bump stops. These truck have a different frame than the GMT800's and from what I was told until you go to a 7" in the rear there will not be a need for a C-Notch.
I am completely happy with the lowering kit (McGaughy's #34160) it still rides like it did when I bought it because it keeps the stock shocks and springs.
Go for it man you can always return to stock but I doubt you will.
  • Replies 36
Every time I look at your truck I just like it more and more haha. For those of you saying to get rid of the trim around the fender your nuts. It's a great idea that should of been put on trucks from the beginning. You now don't have to worry about chips on your fenders and them rotting out. I agree that they need to be colour matched (I'm doing this too) but it's a great idea to have them there.
Can't just take it off. It's held on with clips....
So it sounds removeable to me if it's held on with clips. Correct me if I'm wrong but not all 14's have them.
They look cheap on an otherwise classy ride. :dunno:
The Sierra's have them and the Silverado's don't.
Once they are painted it will look just right.
So it sounds removeable to me if it's held on with clips. Correct me if I'm wrong but not all 14's have them.Every time I look at your truck I just like it more and more haha. For those of you saying to get rid of the trim around the fender your nuts. It's a great idea that should of been put on trucks from the beginning. You now don't have to worry about chips on your fenders and them rotting out. I agree that they need to be colour matched (I'm doing this too) but it's a great idea to have them there.
There are holes in the fender where the clips snap in...
Sent from my SCH-I535 using Tapatalk 2
They should look good once colormatched. Here's a Sierra I found that had them colormatched, first and only one I've seen and I'd love to see more.
can you post a pic of the rear tailgate without the GMC badge please!?! i want to remove mine but i kinda want to see how it would look, if too plain or not! (does that make sense)!
looks great... i wish i could keep my truck that clean... i cant go up my driveway with out getting anything on it
That truck is sick but I couldn't drive something like that as my DD. Seeing that makes me want to drop the mouldings off at the body shop today.
I still have mine on for now. I plan on getting the Plasti-Dip "True Metallics - Aluminum" for the GMC Badges on the front and rear and if I don't like the look after that I will remove.
Here is the Dip I'm gonna use. https://www.dipyourcar.com/plasti-dip-aluminum-can.html
What's up JRoss
Thanks for the reply Low2014. I'll keep you guys posted with what I end up doing. Your truck looks very clean btw!
Thanks man!!
DROP IT!!!! Do a 2"-4" if you're worried but .................you will want to go lower.
  • 3 weeks later...
I jacked up my photobucket and lost the pictures in my first thread so I started a new one for the guys that wanted more pics.
Again this is how it looked when I picked it up.
[/url]
Here is some in the sun!!!
I thought this looked pretty cool.
Thanks for looking
Mark
What drop?
Sent from my SM-T210R using Tapatalk
Looks waaaay better without
    DLZ
    DLZ
  • Who's Online   1 Member, 0 Anonymous, 453 Guests (See full list)
