2014 Sierra humming noise
Oli4
  • Replies 150
Shotgunz71....if you don't mind me asking, what is the led around the knows issue? The red light around my hvac controls are blacked out in spots. Not a full border.
On some early build '14 trucks, the LED rings around the volume, tuning and fan speed knobs were not illuminated. This was due to a supplier issue and GM didn't want to slow production waiting for the correct part (resistors) to come in, so they produced some that weren't illuminated. People started noticing, and GM tried to cover it up by saying they were designed that way. Thing is, some of the very first trucks were working and later trucks were working.
  • 4 weeks later...
I wonder when GM is actually going to acknowledge that this IS an issue...
Gm guy? Would you mind if I contacted the dealer where you got yours done to see if the could give me a lead on what to tell mine?
Update on the NEW front differential that had originally resolved this issue. After roughly 1,500 miles the issue has returned unfortunately. Same exact humming/rotational moaning noise as before.
I have not taking it back in, don't have time for this at the moment and don't expect them to replace it again as they stated before there is no TSB currently for this and they need one from GM.
IMO, I think some front diff's are coming with bad pinion/gear backlash (countless other threads seen same issues with REAR axles) and settings from the FACTORY. So with the bad settings it takes some time before it creates enough "play" incorrect teeth wear etc..and leads to what we all are currently dealing with.
There are some TSB's for the rear axles, just wish they would release something for the front axle so the dealers arms are not tied.
If a TSB doesn't come out for the front differentials / axles by this Spring, I will be putting my truck up for sale and may have to retire my user ID.
Hello all, I am new here and am having a similar issue except mine is a constant whine once it starts. It happened twice today and started at approximately 43 to 45 mph. I was able to get my phone out the second time and capture it. The video is provided on youtube at the following link.
As soon as I got home, I called the dealership and they got me right in to check it out. Haven't heard anything back from them yet. And of course it didn't happen again as I drove to the dealership. Just hoping they were able to recreate it. I did show the video to the shop manager. 2014 GMC Sierra extra cab with about 5000 miles on it.
Mine comes and goes. When it's got just the right load on it and approaching 60 or so. Don't usually notice it on a short trip to town. Kind of hoping they figure something out and issue a TBS or something. Supposed to take my service manager or one of the techs for a ride if I catch it acting up and I'm near by sometime. At first I thought maybe it was the exhaust system vibrating or the flapper valve within it.
Welcome, glassmasterB. Mine does this in/out hum thing between 58-70 mph. It is prominently on the driver's side front end from what i can interpret. Have had my exhaust replaced already to the converter, tires rotated and balanced with no change. It goes away while cruising in that speed range instantly when i put it into AUTO or 4WD. Then when i switch back to 2WD it gradually comes back. One tech thought it could be in the front dif, but of course gm wont touch it until sonebody dies or theres an explosion. :). Forgive me, i have been fighting this anomaly for over a year. Oh, and how about those static ridden dash speakers in hd?! Mine sound like they're blown already. 19,000 miles. Dealer said normal sound. Ha! Ya, if youre drunk.
Kudos to my local dealership for pinpointing the problem so quickly. Just got the call from them and they were able to duplicate the noise. As the tech was driving and the noise was doing it's thing, the tech rolled the window down and pulled in the mirror, as he noticed some visible vibration. The noise stopped. He did this several times and has concluded it is the mirror. Since this is the first time it has happened, and with the weather being so cold, they will have me monitor it for further occurrences. If it continues even as the temperature rises, they will replace the mirror under warranty. So glad it's nothing major!
Man I would be glad if mine turned out to be something so simple. I'll check it out next trip I take but I'm not too optimistic that's what mines doing.
55-70 mph. Whaap.......whaap.....
whaap.....only in 2wd. Driver's side. Not tires. Goes away in auto. If some one has a 4x4 crew cab 20" wheels please tell me if you hear this noise. With radio and vents off. Cruising at the above speeds.
Don't think my problem is a bearing or a mirror.
Sounds exactly like what GM-GUY is thinking it it. Incorrect wear of the gears and then the driveshaft starts to show so lateral play and it literally moves up and down and creating this harmonic noise.
IT IS FRUSTRATING ME LIKE NOTHING BEFORE.
C'mon GM do something here.
Any new light to shed on this issue? I just bought a 2014 1500 crew cab, 5.3, 4X4, LTZ, 3.42 gears. Very noticeable on and off humming/frequency noise (and I think I also feel it on te floor boards) that is especially noticeable from 60-70mph. It is not engine rpm based, nor is it V4 or V8 based. It seems to be noticeable once the truck has been driven and all the fluids are warmed up a bit. It does go away when in "auto 4 wheel drive" and then slowly comes back when switched back into 2WD. Please help me point to a technical service bulletin or a fix of some sort!
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 528 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
