2014 Sierra humming noise
Oli4
I wonder when GM is actually going to acknowledge that this IS an issue...
They already have. The "issue" is a "NORMAL OPERATING CHARACTERISTIC" AND "NO REPAIRS SHOULD BE ATTEMPTED."
  • Replies 150
GUYS! MY TRUCK IS FIXED!
Dealership replaced:
1 Pinion Bearing #15286375
1 Bearing #9413427
2 Differential Side Gear Bearings #20997053
1 Seal (frt diff drv p/gr) #12471590
1 Spacer #12479162
2 Gaskets #15270969 and #15270970
1 Adjuster #15876533
1 Seal #22761722
And of course filled it back up with synthetic gear lube.
The tech's comment was: removed the front diff and inspected it. Upon inspection, discovered scored bearings on the carrier side of the diff. Overhauled and replaced front diff bearings. Test drive ok.
Truck is quiet! FINALLY!!! I had forgotten how that felt.
Funny how a bearing can completely ruin the experience you have with a vehicle. This is now a new truck and I am falling in love all over.
Fingers crossed the scored bearing wasn't a result of something else...
@Oli4, congrats on being persistent and basically getting a new front diff :) in order to resolve it. Welcome to the new front differential club. We all must have got a bunch of Friday made differentials. But your are right, did something externally cause this, or did the manufacturer of the diffs gearing really sucked it up lately (AAM i believe). Since these are the same front generic 1500 series GM truck front diffs/ part numbers going back in previous models.
Another update: I phoned my dealer again today requesting what the game plan is to fix my variable humming issue that I have been posting about. Dealer said that he just got back from a service conference and talked to engineers regarding the issue and they have informed him that my issue is due to "improperly cut rear differential gear teeth". I set up another appointment for April 6th to have it looked at. Based on my extensive research and after reviewing other same issues and fixes I am not confident that this problem is a rear differential issue. I am confident the issue is coming from the front differential but if the dealer wants to start at the back end and work their way forward then so-be-it. :/
Hi Majicgoats,
We do look forward to all of your updates, and know that we are here to possibly look into this further for you. This is definitely a frustrating experience that would never want you as our customer to experience. Feel free to send us a private message if additional assistance is necessary.
Patsy G
GM Customer Care
I hope you guys all have better luck then me on this "humming above 45mph" issue. I've been told my Silverado humming noise is normal operating noise by 3 GM Engineers. I've also been told after the diagnosis by the engineers that the noise was tiore noise. This from a GM technician at another dealer.That's after a zone mgr and another GM engineer told me it was "harmionic Distortion" before they changed the yoke to no avail. This is all experienced on the "QUIETEST SILVERAD EVER PRODUCED" by GM.
All I can say is Forget It when it comes to getting your noise issue corrected. I've seen but one post where it was corrected by a Technician whoi took the tinme and effort to fix it. When I sent that pst to GM they agreed to let me go to another dealer for a diagnoseis. I gave that dealer the post and was amazed to have the Tech tell me all the previous engineers and managers were incorrect and it was road noise that just happened to start about 50 mph and amazingly go away at about 65mph.
I had the same problem but the noise ended up blowing a hole in the front diff case! I put a link to my post below. In summary, mine was grinding/humming then blew apart. Now it is dealer rebuilt (because GM doesn't offer full front diff assemblies) and hums under load. I work in the axle industry and the noise sounds like the hypoid gear adjustment is out of spec and it has improper tooth contact that is only heard under load. If this is the case, the bearings will fail prematurely. Anyway it is now back at the dealer and they don't know what to do. Frustrating.
http://www.gm-trucks.com/forums/topic/171347-2014-sierra-front-diff-issues/
I hope you guys all have better luck then me on this "humming above 45mph" issue. I've been told my Silverado humming noise is normal operating noise by 3 GM Engineers. I've also been told after the diagnosis by the engineers that the noise was tiore noise. This from a GM technician at another dealer.That's after a zone mgr and another GM engineer told me it was "harmionic Distortion" before they changed the yoke to no avail. This is all experienced on the "QUIETEST SILVERADO EVER PRODUCED" by GM.
Perhaps they should call it "THE HUMMIEST SILVERADO EVER PRODUCED BY GM".
... Now it is dealer rebuilt (because GM doesn't offer full front diff assemblies) and hums under load. ...
Hi @rudie20, if you read in previous posts, you will see I received a complete new front axle assembly (although 6 months ago) and so did another. Maybe they are going through the complete front diff assemblies too fast to keep up?? Only takes 1/2 hour to replace a full front diff assembly vs many hours to repair one, set gear alignment and the like.
For those having the issue and want a resolution, you can buy your own entire front differential assembly (applies to both 2014/2015 1500 series trucks) for around $1K , its simply a bolt on installation for the most part.
http://www.gmpartscenter.net/oe-gm/23186399
Of course, since its the same OEM GM product (same manufacturer making these), its probably going to have a 50/50 chance being built with same issues/problems giving you a humming machine, or blown hole through your diff as @rudie20 achieved.
I would love to find a aftermarket beefed up one to replace it entirely. There are not many (ok, none) qualified axle shops around my area I would have undertake that, otherwise I would do that route.
Hi Majicgoats,
Patsy G
GM Customer Care
Thanks to kgwestar, I went to my dealer a few weeks ago (in Vegas) and shared his information, telling them I have the same issue. They had trouble isolating it (not sure why), but they acknowledged it and replaced the front differential. All is well now.
Kylek, glad to hear you got yours fixed! I am still looking forward to my next dealer appointment on April 6th, 2015 in hopes for them to make the repair. I'd like to say I have high hopes but they most recently told me the issue is coming from the rear end so that is where "they want to take a look". Would you (or any others) that have had a successful fix mind private messaging me with information as to any "case numbers" with gm or your dealer information? I am looking for anything that I may help my dealer get this fixed sooner than later.
GM-GUY,
The front differential assembly doesn't appear to be complete with gears. (http://www.gmpartscenter.net/oe-gm/23186399) When you received your new axle assembly replacement, did it come with all the internal components preshimmed and ready to go?
UPDATE: I dropped my truck off at the dealer yesterday (04/06/2015) for further investigation and repair. The service manager wanted to go for another test drive and again he confirmed the complaint. I just got a call from the service manager today informing that they ordered a new front differential assembly for my truck! I am looking forward to getting the truck back and no longer having to listen to that coming-and-going humming noise. Once I get the truck back I will let you know the results. (P.S. - My dealer was nice enough to provide me a comparable truck while mine is getting fixed...I am thankful of that and it goes a long way with showing customer appreciation and understanding to the frustrations of this issue. )
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
