This is for the 2014 Sierra/Silverado 1500
Ok I decided to hardwire my Valentine 1. The install should work for any detector. Others have noted that they could not find a 12v lead off the rear view mirror, so I tried the overhead console.
The console (I have Homelink) pops off very easily. You open the sunglass compartment halfway and you can pry open the edge of the console with just your fingers. You should now see this:
There are three connectors to the console panel: 1 at the front (small black) is for the Homelink buttons, the middle connector (black) is for the LED ambient light, the rear one (brown) is for the interior light switch for the doors.
I tested all three connectors and could only find a good 12v + and - at the rear connector for the interior light switch. The left most yellow wire is 12v + and the right most black is - . The yellow wire is triggered with door opening and stays on until all accessory power shuts off. When you lock the car it shuts quickly, otherwise is remains on for maybe 20 sec
I used vampire taps and wired in the Valentine harness. The cord to the detector easily wedges thru the front of the console out to the area around the rear view mirror. There is also tons of room to stow away any wiring up there.
All tapped in and powered right up:
For tools, the connectors need a small screwdriver to release the clips, and otherwise the only other thing required is taps and a voltmeter. Takes 30 min max
Edited by clayp
Well disregard the previous post - as is the radar detector will not work in the daytime lol! It only works when the nighttime ambient light is triggered.
Back to the drawing board. I removed the old setup and this time removed the entire overhead console - not just the panel. There are two T10 screws to remove:
Then there are two friction fit tabs up front that just pull straight down.
There is a main wiring harness to the overhead console on the left side that you can disconnect.
Testing all the wiring shows that the black wire is a good ground, and the leftmost purple wire with white stripe is a good 12v positve that directly is triggered by the ignition. Engine on, power on; engine off, power off.
Just an extra step but now all seems to work properly. I think the purple wire with white stripe is the power lead to the passenger airbag light on the overhead console.
  • Like 5
Very nice write up. I plan on picking up a V1 later down the road as well. I see it retails for $399, did you find it cheaper and if so can you provide the link/store source? Thanks man.
Unless you do as Won suggested you won't find a better price unless you buy used. Not sure you can get them anywhere but the manufacturer. If you live near them (Cincinnati I think) you can even pick it up in person, or at least you used to be able to.
Excellent write up. Seeing how to remove that console was priceless. This helped me tremendously. :cheers:
I was able to get ignition on/off 12v at the mirror harness with the purple and green wire. Black was still ground. If using mirror tap I would get 15" with nano width for pin.
Do you have a pic of your console? I have the regular cab and it didn't come with Homelink. I'm thinking I should be able to get the panel with the homelink buttons and be GTG, right?
Nevermind. There is no wiring run for the Homelink.
Edited by bigsapper
Has anyone tried running a wire along the headliner, down the A pillar then into the fuse box? That's the way I had my last one wired but I didn't have an airbag in the pillar to worry about.
yes I did no issues.
Did you pop off the cover or were you able to just tuck in?
I followed the headliner tucked it in the arm and then next to the door gasket. I never removed any of the plastic covering
This can also be done through an auto dimming mirror with a lot less work. Thats the way I did mine anyway
Edited by KUUG
I had planned on hooking up my Valentine One using an Invisicord as I have on lots of past vehicles. It just connects to the plug on the rear of the auto dimming mirror. But, my Denali has the Lane Departure Warning option & there is a box in front of the mirror that houses the cameras it uses. There is no plug to tap into.
Has anyone done this hard wire hookup on a truck with the Lane Departure Warning? If so, does it work the same way?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
