recall codes.....
So got a call from the dealership this afternoon, there are 3 recalls on my 2014 Silverado. The woman who called really had no idea what they were and was just calling to schedule the appointment. She did have the recall codes however-anybody know what these are?
ECM, TCM, BCM.
She did say she thought the BCM was related to the doors. I said I wasn't having any problems with my doors and she laughed nervously.
Anyone?
engine control module
transmission control module
body control module
you dont have a letter from the general yet ?
Interesting, checked for recalls from gm.com and shows nothing for my VIN
ECM, TCM, BCM.
Anyone?
ECM/TCM affects the AFM and shifting issues. The BCM update affects the sequence software is loaded when you turn the key on. There are instances where the vehicle wouldn't start for about 10 minutes.
I wasn't experiencing any issues but had all the updates done. Takes about an hour total if your dealer is good at honoring appointments.
OK cool. I don't have any of these issues either but will have done. Thanks
I wonder if the XM cutting out would be fixed by the BCM update. I have to refresh my signal a lot.
I think that thing on GM.com is for full out recalls. but what the OP is talking about are actually TSB's.
not just spotty reception, but I lose sound all together and I cant get it back unless I send a refresh signal from XM. The screen shows what is playing and the song names and bands and what not. Just no sound.
I have been having the same problem.
Its very annoying right?
Yes, I am going into the dealer Friday for snow tires/wheels and to fix my heated steering wheel. I will ask them about this too, now that I know it is not just me. Will let you know if I find a fix for it.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
